Storing cherry log chunks for turning
Jon Grider
>Most of the work I do is with boards and flat goods,so my lathe often sits forlornly in the corner for weeks at a time,so I'm not a very practiced turner.
However the power company came through my property and downed some oak and cherry trees that they felt were a threat to their power lines.Makes me sick,but I now have some piles of various length chunks of cherry that I would like to salvage for small bowl work at a future time.None of the trees were very large,but I do have some chunks that are about 8"-"10" diameter.Any advice on storing these pieces to minimize splitting and checking?Your replies are appreciated.
Re: Storing cherry log chunks for turning
Phil in NJ
>I had a similar sized cherry tree taken down 2 years or so ago. I bucked the tree into manageable length sections, then painted the ends with AnchorSeal. Then I piled them up behind the garage under a heavy plastic tarp or two, to keep the sun and rain off the logs. The AnchorSeal seems to almost totally prevent end-grain cracking, so the yield is excellent. Make sure you paint it soon after cutting.
This has worked pretty well, and the logs are drying very slowly and any time I want a blank, I just chainsaw off a chunk and paint the exposed end again with AnchorSeal, unless I use the whole log.
The advantage of this approach is you've not committed yourself to any particular shape bowl, or indeed bowls at all...
-Phil
