ADVERTISE HERE - FREE TRIAL
Using acrylics
Using acrylics
Using acrylics
Chip in Plano
>I finished turning a piece of cypress. I never got past the fact that I thought it was an ugly piece of wood. Started dyeing it but the soft and dense grain took the dye very poorly. Now I've opted for acrylic paint....but I have never used them before (at least not since middle school).
> What are the critical points to know?
> how do I get a smooth surface.
>I kind of like the brush strokes right now but I might want to rub them out and go for a glossy finish.
>What type of top coat can I use?
Thanks for the primer. I think I might ask for a painting class for Christmas.
Re: Using acrylics
Re: Using acrylics
>>...I think I might ask for a painting class...
You might check into a demo or class with Andi Wolfe - carving, woodburning, and coloration. Very good.
Re: Using acrylics
Re: Using acrylics
keith zimmerman, Normal IL
>Chip, first and foremost, remember that acrylic paint is just that, acrylic (plastic). Hence it will not penetrate into the wood, but will always sit on top. One of the unique qualities of acrylic paint is that you can apply it in many different ways and get a completely different look with each technique.
If you brush it on, it will be kind of thick and opaque. If you thin it with water, then brush it on, it will be rather transparent, but quite runny. If you spray on the thinned paint, it will be transparent, but you will still have total control on how it looks. A single coat will yield a light transparent color. Multiple coats will give you darker and more translucent colors.
For a top coat, I would use something like varnish.
keithz
