Dental picks
Gary Land
>I am wondering how people use dental picks. Do you have to grind them flat a bit? The tips seem to be to pointed to use. I have tried to make a captive ring on a bottle stopperand it seemed to just scratch.
Dental picks
Gary Land
Re: Dental picks
Dick Hines
>The ones with the little hooks on the ends are great for pulling those big old worms out of your bowls before they hit you in the face.
Happy lunch every body! :)
Re: Dental picks
Don at Central Illinois
>Just spin the wood REAL fast and they come out on thier own. DAMHIKT
Re: Dental picks
>Gary I don't think dental picks are the best thing to use. they are too springy. I make my own from old screwdrivers. I file them to shape and heat and bend them if necessary. I like dental picks for miniatures but not for regular sized goblet rings.
Use a small allen wrench instead
steve antonucci
I just altered one into a neat little V gouge
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I have several old ones that I have gotten from the hygienist. I have used them to clean out little bark pockets and things like that, but the other day, I had an idea that I tried.
This tool had been ground down pretty far, and was just a little flat chisel end on it, but I was needing a little V, so I took one of the little diamond die tips which is flat on the end, with a cone shape back down to the shank. I could just barely get it in under the bend, to grind the inside. I then went one one of my grinders which has a fine diamond wheel to grind the bevels.
I was very pleasantly surprised how easy this little tool was to use and control. I think it will be fun to use for little details such as feathers and hair etc.
Re: Dental picks
keith zimmerman, Normal IL
>I use them to clean burl spikes. I have some ground to a tiny scraper, some ground with a hook, and some ground with a point. They work very well when removing the last of the bark from the burl.
keithz
