Re: I had a terrible time!
Fog Tanner
>Most of my turning these days is offcenter. I have three different offcenter chucks that I use for various projects. I started doing a lot of eccentric bowls where the piece is offcenter and at an angle. Even with mt lathe weighing a 1000lbs I was still able to get it moving at higher rpms. I start at around 400 or more and work up to 1500 as mass is removed. For the larger pieces I stop at around 900 now.
With the eccentric chucks I have, there is a builtin imbalance with a large amount of steel being offcenter. I can get vibration with no wood mounted at all. I counter act this I bought the Vicmarc balancing system. This may have been the one you saw. I just finished a large 11" Pecan bowl using the system. The counter balance seems to work with no problems. I worked with the weights before ever turning the lathe on. I found where you had to start from and that it was better to move both a little than one a lot. Once I got the static balance set, I turned the lathe on, checked for vibration, and adjusted the weights as necessary. I wound up with no more vibration than you would with any bowl blank. Its a similar process to balancing a crankshaft - except I don't have the highdollar machine for that.
As the bowl is roughed out all the vibration goes away pretty quick. What used to take me 4 hours to turn was cut down to 1 1/2 hours. And that was one a much smaller piece of wood. I am also using it for the "normal" bowls that I do, just to avoid the inital vibration and lower rpms.
I also do all the "roughing" and part of the finish work with the tailstock engaged. When I rough out the pieces, I cut them as usual with intent of removing as much waste as quickly as possible. This shortens the duration of the most imbalance. I will also use the tailstock on the inside at times while working on the rim. Once that is thinned down I move the tailstock out of the way.
And if you want to do offcenter work of a lager scale then you need some body protection beyond what you normally use. A faceshield alone isn't good enough, you need a helmet with a visor that can withstand a blow. I wear a helmet all the time, and hand protection (left hand) part of the time. And when I can get over to Col. Bubbies I am buying a surplus flak jacket for a turning smock. If you wear glasses and have bifocals, it is worth getting a set of single vision glasses that are good for about the same distance you are from your computer monitor. That keeps your head away from the activity. It is much too easy to "get down and look closer" on some of those finer cuts. At times I also put a piece of masking take on the tool rest at the "Nogo zone". It also helps to put a piece of dark or contrasting colored background under the piece to help you "see" the shadow cuts.
It is fun to do, you just have to remmber that is is much more dangerous than normal woodturning and not something you do unless you are really alert - which what we need is more lerts...Have fun and be safe and careful.
Fog
