Re: Calling Fog Tanner for respirator help!
Fog Tanner
>John,
I got the AS-400. The AS-200 was still available from Airware America, but the price difference wasn't that great. The AS-400 has more airflow, and the summer here in Texas made me glad I went that route instead of saving a few dollars. There is/was an AS-600 which is for coal miners I beleive.
I got the "Smart Charger" with mine, having had experiece with those types of chargers before. It is the only way to go if you want long battery life. Too many batterys are killed from over charging - it will decrease their capacity. At first I didn't want to spend the extra $140, so I did some research. I found a compnay in Australia that makes printed circuit boards for electronic enthusiasts. They had a board for a "smart charger" that would work. I priced the board an componanats and it would have been cheaper, and I have built some of my R/C transmitters, receivers, and servos before - but I decided that I would rather turn wood than make a charger. That and I remembered that I had paid $50 for a smart charger for my R/C planes back in 1980 (actually bought 2 of them), so $140 wasn't that high in todays money. But at $200+ for the battery pack, I will rebuild that. I talked to Raffan and that is what he does with his. Cost him about $35 AUS for new cells. I have built a number of battery packs for my raceplanes, so if I can make a pack good for 200mph I should be able to make one for standing at a lathe. But you should get 5-8 years from a battery pack and a smart charger.
I found two places that had decent prices, one was Airware America and the other was www.envirosafetyproducts.com. I checked the prices of the units and the "consumables" (i.e. filters, overlays, faceseals, etc), Airware was a little cheaper. I had done business with them before so I went with them. I also bought a combination deal they had , consisting of a filter and overlays - which saved a few dollars. It is a good idea to keep a spare filter, visor overlays, and faceseals. You will wearout the faceseal, unless you go with the rubber version (which is hot here). The filter will need replacing depending on your use, you check the airflow with the supplied guage to see when it has dropped below what it should be. Same with the visor overlays.
I paid about $825 with all the extra stuff I got. 3M has a 15% price increase each Feburary whether they need it or not, so you want to do something before then. I need to buy a 10 pack of faceseals and another filter before then too. You don't go through that many faceseals, it is just cheaper by the 10 pack.
The way I looked at it, the money for the Airstream was a lot - but it was still a lot cheaper than a lung transplant or hauling around a bottle of oxygen....plus you can always paint the Airstream some cool color and look like a race car driver or Darth Vader at the lathe and there is not a lot you can do for a green bottle of oxygen...
Good Luck,
Fog
