Re: wet turned bowl question
Greg Haugen
>Since you're "Coring" bowls I'm assuming you know you should have equal wall thicknesses. No real thick bottomed bowls for drying,etc. I'd "control" the drying. Since you say it's "finish turned" you don't want to add anchorseal or anything more to it. I'd put it in a brown bag or even a box (then shut the box's flaps) along with some of the shavings from the turning. The shavings will keep some moisture in the "micro environment" restricting the bowl to dry too quickly.
Wood dries by the movment of air over the surface. Some hollowform turners turn to finish thickness and place the form in a closed box. In a couple of days, they open one flap, in a few more days they open the other. Control. By restricting the air movement or keeping it a little "humid" (with the shavings) for a gradual drop there's less stress on the wet wood to dry.
Another consideration is where the wood came from. Often times you may not know when you see a log felled already. "Trunk" wood usually has an aprox. centered pith and equal growth rings. "Limb" wood the pith is often off centered and unequal growth rings. Limbs don't growth straight up like a trunk usually does. Gravity causes more water in the wood cells to "sag" or stay lower on the limb. The wide section of growth rings is the underside of the limb, the narrow side is the upper side. It's harder for the tree to "Carry" water to the upper half of the limb. Wood with irregular rings can be difficult to dry. Some may call it "reactionary" wood. The narrow and wide rings react differently and often crack at the differences of the stresses. When I come across this I'll take one bowl usually or two but I'll split it so the bowl has the same growth rings, not half and half. This can be done and I've done it but it can cause problems to have a bowl with narrow and wide rings.
Bill Luce is a turner that uses the grain and balances it amazingly. www.billluce.com. I'd also recommend watching John Jordan's DVD Aesthestics and Properties of Wood, which is excellent. www.johnjordanwoodturning.com Our club just had John demo but I missed it, I have seen the dvd though.
When I'm turning bowls to "twice turn" them dry for utility bowls. Sometimes I'll anchorseal the whole bowl and sometimes just the end grain. Depending on wood and how soon I want it back on the lathe. If I just end grain seal it, I'm usually doing a lage batch of bowls and they stay in the shop with the shavings for a day or two to slow that initial drying with the humidity or I'll bag them with some of the shavings for awhile. If I'm in a big hurry, I'll use DNA or finish turn it as a round bottomed utility bowl and let the wood do what it will do. These twisted and warped organic bowls are often the best sellers. Go Figure.
One final though. Large bowls, above 13-14 inches. Are a pain to dry. I've had the most success when I've gone slightly less than the 10% rule but I'm also being very mindful of the grain and trying to balance it. More wood is harder to dry but it's tought to finish turn a bowl and "run out of wood" also. It's a balancing act.
Sorry I wrote a novel. Hopefully something is of interest.
Greg H.
