anyone replace bearings on a woodcraft grinder?---
Ed Kelle
>I have had the 8' slow speed one for about 3 years now. actually it is the second one, the first one went back as it had a good wooble, the second one is not much better. I have replaced the wheels, I use the oneway balancing kit and have rebalanced the wheels at least 3 times. Just seems to be getting worse, not just side to side wobble, but back to front as well. Even the diamond dresser does no good. Now it is leaving nice jagged edges on the tools. I friend has suggested possibly replacing the bearings, has anyone done this and know what size bearings to use? any tricks to replacement? there is no woodcraft near here so going and testing out another or taking this back is not an option. Nor is replacing with the 2 speed Delta as I have had experience with one which was worse than this. right now bearings are the only thing I could afford and hopefully that would do the trick. Any other suggestions? thanks
Re: anyone replace bearings on a woodcraft grinder?---
Re: The 2 main problems with......-
Jamie Donaldson
>....the Woodcraft grinders are that: 1. the hole spacers do not often snug the wheel hole to the motor shaft diameter, and 2. the flanges are pressed discs rather than more accurately machined discs. I have also seen several grinding wheels that were not drilled perpendicular to the motor shafts, and truing and balancing the wheels usually can correct these deficiencies.
Ed Kelle
>yes I agree. The oneway balancers have machined spacers and flanges, which I thought would solve the problem but it did not. Even tried different wheels. that is why we are suspecting the bearings
Pete LaBelle
>Bearing should be heard more than felt. To start showing up on your tools, it would probably hardly run.
The Woodcraft grinder is a cheap grinder and can't be measured against a Baldor quality grinder.
I took the stamped washers off my grinder and turned the faces flat. That helped with the wheel wobble a lot. There isn't much of a shaft step to catch the stamped washer, thus it would be very easy for a wheel to get mounted in a permanent wobble.
Have you put a dial indicator on the motor arbor to see if it is running true ? This would also show any issues with the bearings.
Are you using an aftermarket grinding system? The cheezy tool rests on the cheap grinders do not allow adequate support to any tool and can & do flex under a load.
My thoughts.
Grinding wheels
Galen Vetterick
>May not be your problem but the last set of Norton white grinding wheels I purchased I had wobble and out of round or lope.
Every time I remounted got a different condition. Found the multiple plastic stepped bushings were not concentric or even bored perpendicular. I took the bushing from the old wheels and was able to get things back to turning true. Made me think bearing or bent shaft at first as my grinder is old mandrel and seperate belt driven motor.
Still like the old thing cause I can turn it any speed by simple pulley change. Runs about 1400 rpm now as good speed for sharpening turning tools
