Lathe Conversion help needed!
Rich Pearson in Mill Creek, WA
>I have obtained a DC motor (90 volts - 15 amps - 4800 rpm) in good operating condition from a treadmill, however the power supply and motor controller do not function.
Hooking up the motor, pulley, belt etc. to my Jet 1236 is not a problem but I need to replace the electronics. I am looking for variable speed and reverse-ability. I can deal with converting rpms at the motor to rpms at the spindle head.
Does anyone have a good source for DC power supplies and motor controllers?
I'm looking for a functional set up, i.e. cost is somewhat of an issue.
No "Rolls Royce" OR "Yugo" solutions please!!!
Thanks
Re: Lathe Conversion help needed!
Re: Lathe Conversion help needed! *LINK*
John Peck
>Here's one place to start looking, though I don't know whether it'll work with your motor (I'm not an electrician).
Surplus Center DC Motor Controller
Galen Vetterick
>Not familiar with motor in a tread mill so not sure if permanent magnet or wound filed or if series wound universal motor. 15 amp is a large motor and controller needs to be able to handle high current.
Grainger carries I think Dayton and cheaper Dart but Dart may not go that high on amps. I have used KB electronic controllers but bought the board, speed pot and resistor to match motor. I know the one I used had reverse feature. http://www.kbelectronics.com/
Curly Smith
>You can get rebuilt treadmill controls: Treadmill Doctor
Or, one of these new ones will likely work.
KBIC-120 ($72) The KBIC-120 is a 115 VAC rated 9 Amps RMS @ 45C. The control is designed for 90 VDC PM, Shunt and AC/DC motors. It will control motors between 1/100-1/2 HP (1.0 HP w/aux. Heat sink) by inserting the proper Plug-in Horsepower Resistor.
KBMM-125 ($95) The KBMM-125 is an adjustable speed DC Drive. It will control motors between 1/100-3/4 HP (1.5 HP w/aux. Heat-sink) by inserting the proper Plug-in Horsepower Resistor.
Galen Vetterick
>To get the reversing you want it cost more, so not sure what your
$ limit may be. The KB electronics board I used was the KBCC-R and it is about $265. It is sufficient to handle the higher amp motors as well.
I was in the municipal and industrial water and waste water business for 38 years and used it on some equipment drives called, of all things, "Sludge Suckers". Company called Siemens Water Technologies. Glad I am retired as equipment name matches business name and I do not drink water anymore!
Thank you all!
>I've got several good leads to explore on Monday.
Once again WoodCentral steps up to the plate.
You guys are great!
