I'm Beginning To Understand (1 of 2)
charlie belden
>I always looked at turned cowboy hats, or "patinated" and gold leafed turned vase from a "Why in the hell would anyone take the time to do THAT?!" perspective.
The answer often given "Because I can." seemed inadequate. Mountain climbers can get away with "Because it's there." But a cowboy hat?
And now, probably 10 hours into a totally Off The Wall "piece" I'm beginning to understand.
Still have some work to do on the pickle slices and the tomato slice - and the bacon strips are in the works
Re: I'm Beginning To Understand (1 of 2)
>Charlie Sometimes you get an idea and you simply have to build it. You use whatever skills you have, metal, plastic, wood, on or off the lathe. Figuring out how to do it is half the fun for me. You've done a wonderful job. When completed you should get a good photo and send it to one of the magazines. I'll be it will end up in the gallery section. If you need help with that just give me a buzz.
Re: Great work. but...
Steve in NC
>This looks like so much fun. And the fact that you did it with the kids makes it that much better. However, displaying food items in such close proxiity to all the chemicals is a bit uncomfortable.
Great work
Steve
charlie belden
>Steve Wrote:
...displaying food items in such close proxiity to all the chemicals is a bit uncomfortable.
Been to any "food processing" facilities or read the label on just about any foodstuff at your local grocery store?
I guess I could start with some Platina shellac, you can eat shellac - the FDA says so - which is why it's used for coated pills, sprayed on apples to make them shiny and I think it's used on M&Ms (not EmmeNEmme).
Am thinking about breakfast menu items - prompted by suggestions from Arch Fortiter (Mac's Musings) over in rec.woodworking. A bowl of Cheerios, topped with slices of bananas, toast with grape jelly on the side and a cup of coco with whi[ cream topping.
Blue Plate Special - meatloaf, mashed potato with melting tab of butter - and peas and maybe corn, on or off the cob (Nitterman idea).
Maybe, inspired by J.Paul Fennel with a little bit of Trent Bosch thrown in - a popcorn bowl - filled with real popcorn.
The possibilities are almost endless.
