OT - adjusting to contacts
AndiWolfe
>I'm on my second day of wearing soft lenses and I'm finding it very frustrating. These are supposed to make it so that I don't need to have reading glasses with me everywhere I go. I have 20/15 vision with some correction for astigmatism, but I can't see things that are at reading distance.
I don't yet have my prescription lenses, but am using these temps to learn how to put the lenses in and take them out, and to learn how to adjust my brain to see things near with one eye and far away with the other.
So, my question to other contact users - how long does this adjustment take?
I needed my daughter to help me take out the lenses yesterday - just to tell me when I had my fingers on the edges to squeeze them off my eyeball. I sure hope this learning curve is short. . .
Re: OT - adjusting to contacts
davidwalser
>The learning curve is relatively short -- assuming, of course, you can make the transition. My wife could not. Having one eye for distance and the other eye for close work just was too unsettling for her system.
As for learning to take out your soft contacts, that'll soon become second nature. I can take mine out without using a mirror. It'll become like touching your nose. You know where your nose is (or your soft contact) and there's no need to see it to be able to touch it.
Good luck with the transition!
Ron McKinley
>My wife has been using that system for about 5 years now. It took her about two days to adjust. I tried contacts once! It felt like I had a tire in my eyes! So, I went back to full-time glasses.
For some reason she can't use the far-and-near for night driving and has to switch to glasses.....Ron
AndiWolfe
>David - that's very reassuring. Thanks! I didn't have any trouble taking them out today - first try for both eyes. That was a huge improvement over the 20 minutes it took me yesterday. I'm hoping the transition will get easier each day. I had periods today where everything was very clear - far and close, but if I thought about it too much it was blurry again.
Ron - these soft lenses are easy - I can't even tell they're in and I check every once-in-awhile to make sure they're still on my eyeballs. It does feel very strange to intentionally touch my eyeball to take the lens out, but it doesn't hurt at all. It just seems awkward.
Carole Valentine
>Andi, I have often thought about trying contacts, but the thing that always stopped me (besides the idea of having something sitting on my eyeball!) was wondering what effect dust in the wood shop would have. I have vivid memories of my Ex almost crashing us in the car when a speck of something got under his contact! Let me know how you make out...I may be encouraged to try them if I am a candidate. I am probably not by now, since I really need tri-focals. :(
Jim Shaver - Oakville, Ont
>I am sure it will all work out for you Andi,
I tried contacts a few years ago when I realized I could not see the puck anymore, that is dangerous for a hockey goalie..It didn't go well for me, I could never get them in, I did a few times, they were great, but I gave up on them, it was too stressful for me to have to be able to get them in, so I went back to following the crowd, feeling the puck hit me and finding it (mine, mine, mine)...wearing glasses under my mask was also a problem as they always fogged up......I'm thinking Lasik if I am eligable.
I am sure you will do fine....
Take care,
Jim
AndiWolfe
>Carole - these contacts fit so precisely, I can't imagine anything finding its way under them to irritate the eye. You really have to move the lens off the iris to change the fit and then squeeze them to release the suction on the eyeball.
The reason I was willing to try them in the first place is because Bonnie Klein uses them and says they are the perfect solution for us baby boomers whose close vision is less than optimal. I'll definitely let you know how they do in the shop. I need to get a regular pair of non-prescription safety glasses if I'm going to wear the contacts while working with wood dust.
Carole Valentine
>I guess if the idea is to use one eye for distance and one eye for close, it would not work for me. I would need three eyes - one for distance, one for close and one for mid-range. Maybe they could plant one in the middle of my forehead. :))
>I have the same issue Carole,
If we went for 3 sets maybe we could split on the one set and save some $$??
Take care,
Jim
Joanne Adler in Pt. Pleasant, PA
>Hang in there; it will be worth it! You'll adjust soon. I just finished wearing lenses. I had them for over 30 years, starting with hard lenses and eventually getting to soft lenses so comfortable, I barely knew I had anything in my eyes. Until the end of a long day or when some speck of dust or something got in there (yes, it happens, no matter how tightly fitting they are, sorry). My vision with them was infinitely better than with glasses. The past few years I had to add reading glasses on top of the contacs. I did not try the "monovision", but my mother and sister both did very successfully.
But as well as I saw with the contacs, after 30 years of them, I'd had it. I went through the testing and measurements for Lasik surgery. Unfortunately, the only parts of my body that are "too thin" are my corneas and I was not a Lasik candidate. They could, however, do PRK surgery, which is similar. A little more uncomfortable and with a far longer healing time, but end result about the same--clear vision without glasses or contacs. Neither Lasik or PRK corrects presbyopia (need for reading glasses for closeup stuff) and eventually I will probably need reading glasses again, but for now I do not. And I understand that they are working on a procedure to correct presbyopia, too.
So persevere. You will love NOT wearing glasses all the time. And when you tire of lenses in your eyes, consider laser surgery. It's amazing!
Dick Hines
Dick Hines
>I have to hold my eye lid open to put drops in. I can't see me ever having contacts.
Hey Jim, Lasik...
Steven Kubien
>...is wonderful for those of us who were/are good candidates. I had my eyes done at Herzig (Yonge and Bloor) about 6 years ago and cannot say enough good things about the whole experience.
Steve Kubien
>Took me about 4-5 days to adapt. I wore contacts for many years until I got lasik surgery. I found contacts wonderful for kayaking where glasses fogged often.
As for irritation, the only problem I had when a fiber or eyelash with the wrong shape became lodged at the very edge of a lens. Blinking wouldn't dislodge it and the irritation at times caused my eyes to dilate. This was a problem driving in the sunlight, causing me to pull off the road and fix it. My bigger fear was it would happen one day while flying an airplane where it was not convenient to pull over! Fortunately, that never happened.
My wife wears two different contacts - one for near and one for far vision. She claims it works OK but I think that would drive me crazy.
