Re: Sharpening question I forgot to ask at Five Ba
Greg Haugen
>Wilbur,
There is a purpose for everything. Honing is most often done to the inside of the gouge's flute. It's easier and less likely to "roll over" the edge that was just sharpened compared to trying to hone the "bevel" that's only 1/8 to 1/4" wide. For the most part, bowl turners like the edge right off of the grinder. Think of it like a bread knife and bread. Some also like a honed edge. Spindle turners will hone their skews and sometimes the inside of the gouges. Alan Lacer has a diamond hone with radiused profiles on the sides for this purpose. Skews have to be "scary sharp". A grinder's wheel doesn't produce a keen-enough edge. So they should be honed with a diamond hone, etc. For stubborn woods I'll take it one step further and polish mine on a mdf wheel charged with White Rouge to an near "mirrored finish". Nick Cook uses a tormek for a lot of his sharpening. His skews will still come off the tormek (a very fine grit wheel) and will be honed either with the leather strop of the tormek or a diamond hone.
Honing has a strong foundation in production turning. Instead of stopping, going to a grinder to touch a tool a turner could simply take a diamond hone from their apron's pocket and touch up a tool in a few swipes and be back turning in a couple of seconds. Time is money.
I'd recommend for you to try it both ways. Start a bowl and put a fresh from the grinder edge and make a few cuts. Then do the same thing with a honed edge. I have also seen turners make their own "slip sticks" with a turned dowel and some of the black wet/dry sanding paper. Diamond hones that are used by turners are usually 600 grit.
An interesting side note. A bowl gouge is one of the only woodworking tools that is sometimes used without a keen sharp edge. You'd never use a chisel, planer, or jointer with that kind of edge on it.
Scrapers. I use scrapers in box making. My sharpening technique I've learned from Chris Stott. I'll hone the top of a scraper before I grind it. I want to remove any "remains" of the previous burr. I want a fresh burr. If a scraper is too aggressive or dealing with a wood that is a known "grabber" I'll hone the fresh burr back off after sharpening. This takes alot of the aggressiveness out of a scraper. Also, even though I haven't tried it, there are some that are honing the grinder burr off and raising a new "uniform" burr afterwards with a burnisher. Recently I was talking with Don Derry about this. It's supposed to be a better finish to the cut/scrape and have more control compared to a grinder burr. Think of that bread knife again and then roll it over. Not a great edge and not uniform. Now take a keen chef's knife and roll the edge, a nice uniform keen edge. It's also a "cabinetmakers" technique for cabinet scrapers. I have not tried this, but wish to do so soon. I've used "grinder" burr or No burr scrapers.
Hope this helps. The main point is to try different things (grinder edge vs. keen edge) and see what works for you.
Greg H.
