A55 Smoothing Plane
Sanding question I forgot to ask at Five Barns
wilbur
>Stupid me. There I was with all that expert turning advice at my disposal, and I for got to ask the two questions I wanted to ask. I blame my boys for distracting me. :@)
Here's my sanding question, which I already think I know the answer to. After I finish turning the inside of a bowl, the bottom has a nice curve to it. After sanding, there tends to be a small hump in the center of the bottom of the bowl. I think that this is because as you get to the center, the speed of the rotation gets less, which lessens the effect of the sandpaper.
The only way I can think of to deal with this is to make sure I spend extra time sanding the center of the bottom of the bowl. I was wondering if there are any other strategies for dealing with this.
Re: Sanding question I forgot to ask at Five Barns
Dominic Greco in Richboro PA
>Wilbur,
I tend to form a concave surface on the base of a bowl. This allows it to sit on a table better. In addition, if the wood moves the bottom won't "bell out" and cause the bowl to rock when it sits on a table.
See ya around,
Dominic
wilbur
>Oops -- wasn't clear. By "bottom of the center of the bowl" I mean the center of the inside of the bowl. But I get what you mean, and I like to make a small concave area on the bottoms of my bowls, too.
keith zimmerman, Normal IL
>Sand the bottom of the inside with the lathe turned off. I use my power sander to take care of any 'bump' that is on the center...VERY lightly. You can also hand sand the area.
keithz
Re: Sanding question I forgot to ask at Five Barns *LINK*
Donna Banfield
>Wilbur, you wrote: After I finish turning the inside of a bowl, the bottom has a nice curve to it. After sanding, there tends to be a small hump in the center of the bottom of the bowl.
I'm going to presume that you are power sanding your bowls. If so, you may be spending too much time sanding the bottom of the curve and bottom of the bowl. This area of the bowl has side grain, which sands easier than the end grain, which are the tops of the wood fibers, and therefore 'stronger'. So if you spend as much time on the bottom section of your interior curve, you'll be removing 'more' material then you need to, which may be the reason you have a small 'bump' at the center even though you had none when you started sanding.
I know that this is mentioned in many videos by the experts, but the most recent one I saw talk about this was Mike Mahoney, who has a short 5 minute clip on YouTube about how to power sand bowls. Here's a link to it below.
http://youtube.com/watch?v=aY3JHxa7HwA
wilbur
>Actually, I'm just using a folded up sheet to sand, not power sanding. But thanks for the link to the video -- it was still helpful.
