Finishing platter
Finishing platter
Finishing platter
Galen Vetterick
>Hope you will put up with novice and questions on turning. Thanks to those who helped on sanding inside hollow forms. Turned my first little platter in hard maple. First time to chuck inside of a base and practice on shear scraping. Was very pleased with it but should have left well enough alone. I felt with cutting into differnt levels of grain and end grain I used a sanding sealer before I put on a colonial maple stain to try and show off the grain better. MISTAKE!
I still ended up with a splochy finish as some areas still took stain heavy and others very little at all. Now only recover looks like paint it black! I would take suggestions on how to get a uniform finish when turning a platter and differnt levels of grain to deal with. Thanks.
Re: Finishing platter
Don at Central Illinois
>Instead of a paint job, can you sand out the finish and start over? Check on Russ Fairfields finishing tips on the left side of the page.
>Sorry, too fast on the enter button. It's under the articles section.
Al Neighbors
>Galen, I've found that when I'm going to stain a piece that has both types of grain showing, it helps to use Minwax Wood Conditioner. It's a substance that you apply, wipe off the excess, wait 10 minutes or so, wipe it again, and then apply your stain. It makes the stain apply more evenly over both the end and side grains.
Since I've quit flat work, I haven't used any stain... I just want the wood to be natural. Some folks like to apply different stains to wood that's sort of blase', though.
Anyway, the Wood Conditioner will help.
Galen Vetterick
>Al
Thanks for comments, it just leads to more questions on finish for turnings. When to stain, what type of finish and gloss or not?
Oh, I did not post right for the platter was treated with miniwax wood conditoner not sanding sealer. Maybe just not enough coats to soak into the open grain before staining. Was sanded to 600 grit so maybe some grain too polished to take stain.
I turned three cherry bowls. One natural wood and woodturners friction polish, one with cherry wipping stain and satin wip on poly. The last was stained as well but gloss wip poly. Gave my sister choice of bowls and she picked the stained high gloss. Guess it is in the eye of the person who is given the choice of gift, not my eyes.
So many segmented turning I see on line or shows are high gloss to look like a glazed porcelain vase. Must be what sells or at least shows well. For beginner like me I need a book of when to do and not to do on finishes! Takes longer to finish anyway so maybe I'll stick with truning and just go natural, oily finger prints and all.
