Re: Turning Antler
Scott Greaves in Blackfoot Idaho
>Hi JB,
Antler makes a nice pen! I like to cut the sections of antler a little longer than needed, then mount it to the lathe between centers and turn it so it's at least somewhat more symmetrical. This makes it easier to drill, and the turning process later is speeded up by not having to take off the odd protrusions. The center of antler is kind of like a hard sponge, so I like to use polyurethane glue to glue the brass tubes in because it expands into the porous material better - just my preference. If in the process of turning the pen you cut down through the outer layer of the antler so that some of the porous stuff shows, sand with some CA glue to act as a sealer.
This is like the cliff-notes version of how to do this. There are some really nice articles on working with antler over at the IAP. Good luck! And have fun with this nice material!
Scott.
