OT need help with table saw
Stacey S
>My wife found a plan to make some wooden quilt squares. They involve individual pieces of wood cut into shapes to look like quilt patterns. Anyway I am trying to figure out how to accurately get the triangles cut. Can someone suggest how I need to do this. They are 90deg triangles with the long side being 2.5" long and the short sides approx 1.25". HELP!
Stacey
Re: OT need help with table saw
jwoodwright
>Stacey,
Think segmented turning. You make your strips of each wood the correct thickness and width. Then with a sled mounted on your table saw, make a fixed fence to give you the proper angle for the cut-off. You should be able to add a stop to get correct length.
Or, use a power miter saw and cut pieces, after you make the correct size strips.
Whichever method, use a good blade with at least 80 teeth. I have a Rigid Brand that gaurentee's no sanding.
Sandpaper glued to the sled fence stops "creep"...
Take care and be safe. John K.
