"HOW TO CUT CORIAN"
dtaylor15
>I have some Corian pieces, that I want to cut up, do I need a special blade to cut them on a table saw?....I have cut them on my scrollsaw, but these are much larger pieces, any advice is as always appreciated...Dennis
"HOW TO CUT CORIAN"
dtaylor15
Re: "HOW TO CUT CORIAN"
Jim Canning
>I have worked with Corian a little, you can cut it with a circular saw or a table saw using a carbide tipped blade. A triple chip blade used for cutting aluminum or brass works best, but a standard wood cutting blade will work but it wom't last long.
Cyril Griesbach
>I've cut a fair amount on my bandsaw with few ill effects other than the clean up. Our local kitchen counter top specialists use common wood working tools with corian.
jwoodwright
>I've cut plenty. I use a 7 1/4" 40 tooth blade on my Delta Contractor Saw. 60 teeth are better. Some is tougher than other, just need to let the blade cut and not force it.
I've made too many pens to count. It's messy to cut and turn. Use less expensive tools, they dull quickly.
It's also a Health Hazard, so plenty of fresh air or a powered respirator.
For finishing, wet sanding with carborundum paper keeps the nasty dust down.
Have fun. John K.
