Re: natural bowl
Lyle Jamieson
>There are many ways to mount questionable wood. If it were me, I would put it between centers. Use a balance point not a geographical center point for holding between centers. Now you are under control and can get the lathe speed up to do some information gathering. Clean off a spot and make the surface slightly concave for the largest faceplate you can get on it and make sure you have loads of screw holes in the faceplate. The faceplate will then have a good seat around the largest diameter. I dont ever try screw a faceplate on a chainsaw cut. I would never use a chuck either. Now you can evaluate wheather you want to take the risk of turning it or discard it as a bad idea. Be careful you could get hurt. Remember JJ's famous quote, "Life is too short to use S**tty wood" Someone recently cleaned up the quote to read "crappy wood" but I think the original is correct.
If you still want to proceed a way to hold a questionable hunk of wood would be to drill holes into the wood about 3/4 inch away from the faceplate, and parallel to the faceplate. I use 3/8 drill and then fill the hole with a 3/8 inch dowel. Drill the holes so that every screw intersects the hole and dowel. The dowel is cross grained to the screw and will give you a very secure grip.
