Have a question? Ask Woody!
Favorite Piercing burs
Frank in MD
>Saw Binh Pho, Malcom Zander and more in Richmond and can't wait any longer to try piercing. Have ordered a NSK, but confused about the best burs to use to get started. Any recommendations on shape, size of bur tu use? my best guess at the moment is a 2mm carbide crosscut with either cylinder or taper shape? Thanks for your help!
Re: Favorite Piercing burs
Darryl
>Frank you want something with a taper so that it can cut into the wood as you start. Bin sells I think a #169 or 170 taper. Try this web site as well
http://www.turbocarver.com/burtypes/body_burtypes.html
I've also found some good ones at www.treelineusa.com I think I used their 168 tapered. Be careful about the long ones since they do break easier. With my lack of skill in getting the walls thin enough for the shorter ones I tired the logd stuff and found they need a lighter touch. Darryl
Marvin Ewing
>The FG699L or the 169L are the two best for piercing. The 699L is a little fatter - the L means it's a longer than the 699. Make sure you get the FG which is friction grip for the NK. I buy all of mine on e-bay. A Dental Supppy sells them for $1.10 with shippling included. When you search on e-bay put in dental burr 699L.
