>I use a skew very little mainly because I don't do it very well.
When I turn a cylinder , after I get it round sometime I will clean it up with a skew to get a little pratice.
When I'm turning spalted maple that I have the skew will bounce causing sprials. Increasing speed seems to help as does taking a deeper cut but I still get it. Don't rememenber getting this on softer woods.Anyone have ideas.
>There are a few things that come to mind. First of all is how long and skinny is the spindle. You can get spirals from chatter due to the wood flexing.
The skew needs to be really sharp. If it's dull you end up pushing on the bevel to get it to cut and that can cause chatter.
Some woods have hard winter wood and soft summer wood. The skew, or other tools for that matter will bounce on these and chatter. A sharp tool with a light touch on the bevel usually takes care of this problem. It bad cases like this I simply go to a tool with smaller cutting edge like a 3/8" spindle gouge. Even then you have to just kiss the bevel to the wood and try to take light cuts.
Since I posted this I've turned another peice of this maple and was able to get it smooth with a small gouge. So you must be right about the wood ,makes me feel better.
>I agree with John. All of those reasons can cause the spiraling, or better known as "chatter". You can lessen that by supported thin pieces with a finger as you cut. This is more of an intermediate technique but a good one to learn. The sharper you can get the skew the less force it will take to cut, hence the less flexing and chatter. Also high speeds can automatically through a thin piece out of round by whipping and flexing it as well as excessive tailstock pressure. I'd strongly recommend the two skew DVD's by Alan Lacer.
Hope that helps. You've got a great person on this forum to help with tool issues. John Lucas is an excellent "Tool Technician".
>Ronnie One other thing that helps is to try cutting with the skew at a different angle. Lets say you did the first cut with the edge at about 45 degrees to the direction of cut. You might try flattening it to 35 degrees or increasing the steepness to 60 degrees. The idea is the new angle takes off the tops of the old chatter. All that Greg and I mentioned is still necessary but sometimes this gets the wood smooth again for further passes.
The stock I'm turning is only about 10 in. long and about 1 1/4 in to 1 in in diamenter so I don't think whipping could be a problem.I'm going to try a differnt attack angle and see if that helps .As I said in a previous post I did get it smoothed out with a small gouge just not with that finish you get from a skew
>or the figure in the wood bouncing the skew. Sharpen the skew really sharp, take a light cut and try not to put pressure on the bevel and you should solve the problem.
