Scotchbrite colors question
Gary Evans Tallassee, TN
>Hi all,
I have acquired some Scotchbrite through a couple of different sources and can't for the life of me remember how the coarseness runs from one color to the next. I have some gray, some green and some white.
Obviously, besides having a short memory, I'm also too dang lazy to go look this info up somewhere, so I really appreciate your input. 8^]
Gary
Re: Scotchbrite colors question
tek-Brunswick, Ohio
>The Green is the fine. The Gray is very fine. The white has no abrasive at all. Woodcraft now carries gold and that is finer than gray. There is also a maroon, which is coarser than the gray, but I cant remember if green or maroon is the coarsest.
Tom
>Thanks Tom,
That's what I was thinking, but it's hard to know if the memory is faulty or not. I guess I need to look for some of the gold. I want to polish some aluminum motorcycle cases. I'm told scotchbrite and WD40 are the winning combo.
Gary
BobM
>Gary,
I have some green that a friend gave me and it is much courser than the maroon.
Cyril Griesbach
>tek,
I have some maroon and it is marked "very fine"...what should I believe?
Vince Welch
>Maroon is about 320 grit
Grey is about 700-800 grit
Gold is 1200
White is Non abrasive
Vince
Re: Scotchbrite colors question  *LINK*
Stuart Johnson
Scotch-Brite Pads --- pdf
George Van
>Gary, I have found a definate difference between #M and other brands, color for color. I stay with 3M but I thin the important part is like sandpaper and run the grits from the same manufacturer.
tek-Brunswick, Ohio
>I've had some Grey non-woven pads leave random deeper scratches and some that were more consistent in their scratch pattern. I'm not sure which brand did which. Does anyone know how the different brands compare? BTW I really like the gold pads Vince has.
Bill Crommett
>Can anyone tell me where green fits in ?. Manufacturer unknown, but probably NOT MMM
Colin Spencer
>The ones I have purchased in the UK were marked from coarsest to finest are
Green Maroon Grey White which seems to bear out what has been posted here
