Re: Cole Jaws
Re: Cole Jaws
ebd
Re: Cole Jaws
ebd
>I have two sets of Cole jaws (large and small) for my Axminister chucks. I find them extremely precise when set up properly the first time. I find no inaccuracy built in. I'm not sure what you are talking about.
Re: Re: Cole Jaws
Re: Cole Jaws
Russ Fairfield
>Of course you have no idea what I am talking about. Your Axminster chucks are the tightest fit and the most accurate of all the chucks being manufactured. The plates of the Axminster Cole-type jaws are similar. They are thicker solid plates, and the holes in them accurately located. They also have the white buttons that don't mar your work. Not all of the similar jaws are that way. There are some sloppy fits, thin and flexible plates, and more than a few misplaced holes on the plate surfaces. Add to that there is nothing that will accent a sloppy fit of the base jaws to the scroll than a set of Cole-type jaws. You do get what you pay for.
Re: Re: Cole Jaws
Re: Cole Jaws
Russ Fairfield
>and, I forgot to mention the worst problem of all - plates that are warped or not machined accurately, so the jaws don't all spin in the same flat plane.
For quality of flat jaws I would rate Axminster at the top, followed by Nova, followed by everyone else. Just my opinion from using a lot of chuck jaws over the years. Others may have different mileage.
Re: Re: Cole Jaws
ebd
Re: Cole Jaws
ebd
>Wow, wow, and wow! You are right - I had ABSOLUTELY no idea. I originally purchased Axminster because I wanted the best even though I felt I would be paying an unnecessary premium for the name. I figured that most chucks would be about the same but the number of types of jaws tipped the scale. I'm SO glad now that I didn't scrimp.
Over time I've worked up to 3 chucks and 7 sets of jaws, all of which I use regularly. I find them all extremely precise. I have no problem remounting a piece several times, back & forth, and having it run perfectly true every time. I guess I'm very spoiled. Next batch of mad money I get will be spent on a few more Axminister bodies.
BTW they are made in Poland by Buffalo. I wish I could find a distributer in Poland as I have a soccer team mate that travels there occasionally. Would probably be much less pricey purchased there.
