>Another beginner question. I just set up a beall bowl buffing system. A couple of questions actually, when working with burl, I like to leave the small voids in the wood, however the white diamond compound seems to get stuck in these small voids, what is the best way to clean them out, shy of fillling the voids?
Also, I bought some medium buffing whells from Lowes and made my own make-shift beall system, is it detrimental that the whells are not specifically the same as the beall system?
Oh yea, how much of the compounds is too much to add to the wheels?
>Chris, I just avoid any wood with voids, dark wood with pores (walnut), etc; since I have no idea how to get the white specs out of the wood.
My recall is that using the right "wheel" is a matter of the type, not maker. But right now I am no recalling if the wheel is felt, cotton, or what for white diamond.
>The DVD from Beall tells the material that each wheel is made from. The usage has been learned from experience over time. It is very important to use each wheel with only one compound. Mixing tends to ruin the wheel.
If you do not have the DVD, Beall has an 800 number and they are very helpful.
I use the Beall system on almost all my turnings.... I have never had a problem with leaving compound in the voids.
It is important to load just a small amount on the wheels. A little goes a long, long way. But I do use seveal coats of Waterlox on most of my buffed pieces. That may help to seal the open grain on Walnut and other similar woods.
>Chris wheel material doesn't seem to matter as much as I thought, at least for most finishing applications. Possibly for the extremely glass like finishes it might. I started with the Beal wheels and still use them a lot but I have other wheels that I've picked up that are smaller or different shapes for other projects and they seem to do fine. I don't do the glass smooth on most of my work just really glossy.
I'm pretty sure I use less compound on my wheels than most. I've been using my 4" wheels for about 4 years now and the tripoli wheel apears brownish with white still showing through but some people think it still needs to be charged. The white diamond and wax wheels are hard to tell apart because they don't appear to have anything on them. I simply do a light swipe or maybe 2 when it appears that they aren't doing their job.
How do you tell if they are working. When the tripoli wheel is working the finish will appear to be satin. (if you start with a gloss finish such as gloss lacquer or minwax wipe on poly) I use this wheel until the whole piece has a satin look and everything looks even. I try to buff in two directions if I can because it makes it easier to seen any defects left in the finish.
Then go to the white diamond and it should appear glossy. When I go to the wax wheel I don't see any difference but you can feel the difference. The wood feels smooth instead of waxy. For this reason on dark woods with heavy pores I simply skip the white diamond. I do the same on white porous woods like Ash, I will skip the tripoli and just spend a little more time with the white diamond. This is on woods with little or no finish. If you build up a finish the pores should be filled enough for this to not be a problem.
I use an old tooth brush to clean out residue left from the wheels in pitted areas and on occasion a tooth pick. In bad cases I used mineral spirits on a rag but this removes all wax so you will have to use the Carnauba wax after this step.
I agree with John. When in doubt for either dark or light woods skip the contrasting compound. That's also mentioned on Bill's (Grumbine) first bowl turning DVD. I've also had carnauba fill voids before and show up as light spots. This is the reason why the better "paste waxes" are available in different tints. Since you have "other" wheels you could also try "Hut" waxes that are different colors for buffing. Another factor in this issue is how "sealed" and better yet "pore filled" the finish is before you buff. Some finishes fill pores better than others. The species of wood as well as coat thicknesses, and number of coats are factors to consider. In the case of voids in burl, you're S.O.L. unless you going with the 20 coats of Lacquer like those who have the "optically perfect" glass finishes.
As far as other wheels, I could be wrong, I believe "linen" or "muslin" for general buffing and "flannel" for polishing. All three of which are available at most hardware stores in 4' and 7-8" sizes. Also I was just on Beall's site and saw this- http://www.bealltool.com/products/buffing/otherwheels.php Horse Hair and String buffs. They're talking about the horse hair brush to be used to get into the "nooks and crannies" of carvings. For a soft buff, I'd bet it would work on burl. It's more for paste waxes but as I mentioned earlier you can buy different tints in paste waxes.
>Buffing speed is another factor that affects the way a wheel works. A fast speed makes the wheel harder and can easily burn through a finish. A slow speed makes the wheel softer so it can wrap around details better and will get in the pores to remove some of the compound a little better. I know Beal recommends the 8" wheels at 1750 rpm. I use 4 inch wheels at about 1000 rpm so my surface speed is way below what they recommend. I know others who use the full speed quite successfully so think speed is more a way of how you use it and how comfortable you feel.
I'd like to hear what others have to say on this topic
I'll admit I don't buff. I have in the past and sold my Beall system. It's a great system but I'm a very "functionality-minded" turner. The beall system is great for "artistic" pieces that may not be handled a lot or abused. Most everything I make, exception of ornaments, will be handle a lot and abused, treenware, door stops, and a multitude of spin tops. I like a finish that if I or the customer would like to "maintain" it's possible. Most "common" people don't have a beall system in the garage. That's why push comes to shove I prefer a hand buffed paste wax over a buffed wax. I also don't care for a real glossy finish on most things. I much prefer finishes like Waterlox or other oils and varnishes that I can build up to the sheen I want or use it to "seal" something and then hand-buff it with a paste wax.
Some of my Pull tops I and paint with acrylic colors. I do have a small "hardware" store wheel I chuck up in a Jacob's chuck and use at slow speeds to "smooth" out the brush strokes to a very uniform appearance. They're sealed and then hand buffed with wax.
>Oh yea, that was another question. I just put them on an old craftsman high speed grinder, two on one side and one on the other. Seems like I need to do some investigating into a new motor. Add it to the running wish/need list (its like two pages long) :)
>I frequently have details that are hard to buff. Areas that are sharply defined or too small for the wheel to get into. I bought a buffing kit from Dremel. It comes with lots of different sized wheels. I charge these with the compound and then use the dremel to buff the smaller details. The wheels are stiffer so they reach into places better. Because the dremel runs so fast even at slow speed setting you need a light brief touch or you can burn through the finish but it works great.
