Checks and Cracks in drying wood
chris krohn
>Another beginner question: This is my first year turning, and over the winter I went wood hunting crazy, cut a bunch of wood into semi-circular blanks, some roughed out, and now as it is heating up everything is cracking and turning into firewood :( I know that many of you do not mess with any wood that has checked during the drying process. However, what about insterad of getting discouraged and thowing it out, after the blank has dried and is cracked, why not fill it with another type of material, be it stone, or a contrasting wood? Would this be stupid and amateurish as long as the blank is not covered with checks and cracks?
Thanks
Chris
Re: Checks and Cracks in drying wood
Rick Allen
>I think that most of us do the crack filling thing at some point. It is a good skill to learn. It is good to see how filler materials interact with different woods. This learning process could be done without making bowls and if the focus was more on how fillers and wood work together then you could achieve better results faster.
Cracked and checked wood is a disappointment to be sure. But you should have learned something in the process. You never mentioned using a green wood sealer. Perhaps you should revisit your procedure for processing fresh cut timber into bowl blanks. That effort will pay off big down the road.
What can you do with all of that cracked wood? Firewood is an excellent idea. There is something about working a couple of hours on a hunk of wood (6+ hours if filling cracks are involved) to make something which looks beautiful. And then find the beautiful bowl cracked in 6 months to a year. You can learn from that process also. But I think the disappointment of failed finish work is worse than failed rough work. Failed rough work tends to be private. Failed finished work tends to be more public.
There are two primary procedures for filling cracks. One is to use CA glue and some filler like coffee grounds. The other is to use epoxy and a filler like brass key shavings. The CA glue methods (there are many variations to the coffee) is a LOT faster and many folks like the effect. Epoxy tends to work better on larger gaps. There is a larger learning curve with epoxy.
Good Luck
Keith Tompkins
Keith Tompkins
>HI Chris, something else you can do. First study the blanks to discover where they cracked...with experience, you will begin to spot troublesome blanks and pass them up. A cracked blank can be cut up on the bandsaw for making boxes and other small items. remember, a cracked blank is now weakened structurally...care must be used if you decide to turn a cracked piece. You really should rough out the blanks asap to avoid the problems you're having.
Fred
>Has anybody tried the alcohol soak method for drying wood?
Steven Kubien
>I use DNA and love it. I do not have a huge amount of space to store drying blanks and the DNA allows me to turn over stock much faster. I have used it on pen and stopper blanks as well to good effect. On these smaller pieces, I don't usually bother with wrapping in newspaper (or bagging them). Some crack miserably but most are just fine. I tend to throw these pieces in a plastic bin with some air holes drilled. Picking pieces from the bottom ensures that they have dried for a month or two (or 3 or 4 or...).
Cheers,
Steve Kubien
Barbara Gill, Remlik VA
>Yes, I have but I only use it occasionally. I have had very good success with it. Dave Smith's article about using denatured alcohol is in the Article section.
Steven Antonucci
Not wood, but roughouts...
steve antonucci
>I use it frequently with bowls after roughout. It works as advertised.
Steven
chris krohn
>Yea Roger that, I just need to not collect too much wood at one time.
Thanks
Chip in Plano
>I have had good results with DNA. I rough out then soak. The only problem I have is not re-sealing the wood after I take it out. That's just me forgetting about the blank.
Harvesting your own wood means you have the opportunity to figure out how to deal with cracks. Massive cracks are firewood. Everything else is an opportunity to re-turn it or fill it. Inlace is stinky but the outcome is nice. Epoxy alone is ugly so I add artistic dyes to mine. Brass shavings are easy to get at any home improvement store that cuts keys.
I had a pair of rustic cedar candlesticks with a split from end to end that I filled with turquoise colored epoxy. I sold them before they left the box. I sold them at a huge discount. I thought people would see them as flawed. Exactly the opposite was true.
jim miles
Jim Miles
>Chris: A method I use sometimes if it is a cracked blank I really want to try to save is to use wedges- screwdrivers- to go ahead and split the wood apart- then if it fits back together glue it back together. If you can get a decent glue join, it will have plenty of strength, and may not show badly. Drying wood I think is just one of those skills you have to work at and make a few mistakes to learn how to do it, everybody has there favorite method but I don't think there is any magic solution that works every time. Find what works for you.
