200+ woodworking book reviews
McNaughton bowl coring
Lan Brady
>Today, I tried to use my bowl coring tool on a Powermatic 4224.
The tool post is too short!
Is there a special tool post that I should have ordered?
Lan
Re: McNaughton bowl coring
Dick Hines
Dick Hines
>Lan did you order the support post for the right size lathe? The one for my 3520 was ok.
Check with Big Bill, he uses the coreing system all the time.
Lan Brady
>Dick,
That was my concern. I bought the system off the shelf, I did not know that you were suppose to order by swing size. I wonder if I can can order a tool post only?
Lan
Greg Haugen
>Where did you get it from Lan? Craft Supplies would probably work with you, same with Lee Valley. What is the measurement from the top to the end of the post on the PM tool rest?
Greg
Gary in Zirconia,NC
>Lan,
Yes, there are 2 sizes of tool posts. I run into the same problem. They will give you a longer one at no charge. The Powermatics take a longer post.
Gary
Lan Brady
>Gary and Greg,
Thanks, I got it from WoodCraft.
I will go by there tomorrow.
I appreciate the information.
Lan
Re: Same situation here, Lan.
Al Crandall -NE of Indy-
>When I bought mine several years ago at Woodcraft, I was already aware of the problem because Bill Grumbine brought his to my shop to demo it and we found out about the "shortcoming". For reasons not germane to this post I was given $50 off the shelf price and told to go have my own support machined. It cost more than $50, but I got a better rig because I had it made from 1.5" dia stock. The larger post body sits on the top of the banjo so the cutter is at dead center every time without measuring, and it can never be set below center because of the shoulder on the post.
Dick Hines
Dick Hines
>See what you get for buying that big lathe.
When you get it set at the right height get a piece od PVC and cut it to fit the post. Or you could go to a hardware store and get a collar. That way the post is always at the right height.
Lan Brady
>Al,
Thanks, I hope they have resolved this problem. Custom metal work is not the inexpensive way to go for sure.
Lan
Lan Brady
>Thanks Dick,
As soon as I get a post , I will mark it for further use.
Lan
Jorge Castaneda~Downeast Maine
>I just made a cylinder and bore a hole same size as the post, before that I did set up the coring jig to be exactly on center and measured from the distance from the top of banjo to bottom of turret, then cut the cylinder to that size, now not only it gives me automatically the proper height, but also it cannot collapse, as my Nova 3000 is prone to do.
Hope it helps
Jorge
It was not my idea, somebody here in Woodcentral posted it
Lan Brady
>Jorge,
Thanks so much. I have several good ideas to work with, once I get a taller tool post.
Lan
