Re: Skew's me
Greg Haugen
>Jim,
I've been turning for three years and for the first 6 months all I had was a scraper and a skew. The skew is now my favorite tool by far. I agree with John, Bowls and skews are very advanced techniques and shouldn't be attempted.
First, what skew are you using? Standard, oval, or round?
Second, how are you sharpening it? No matter the method skews need to be sharp. Straight off of most grinder's won't be enough. Diamond hone or waterstone/oilstone at the minimum but could also power strop polish it.
What kind of Angle do you have on it. There are two different grinds, the standard or straight and the Radiused/Raffan/Lacer grind. A starting point, some choose to vary it, for either grind is 70 degrees between the toe and heel of the skew-point to point. The degree angle is the same one just has a flat section in the upper third then a radius down through the lower third (toe to heel).
Skews have two negative reactions, the skate and the catch. The skate occurs when the bevel is lifted off of wood and the edge cuts deep and "skates" backwards leaving a spiral in the wood. The catch occurs when the cutting action passes into the top half/third of the skew. It should be in the lower half/third. When the wood cuts higher on the skew the force changes from controlled to uncontrolled and the point is pulled into the wood where it usually "snap" "crackle" "pop" (rice crispies-just kidding- had to) will tear a section of wood out along with some of your nerves. Both reactions can be lessened by using a "safe driver", either the oneway cup driver, a steb driver, etc. In the case of a catch or skate the driver simply slips stopping the wood from spinning. A spur drive cannot slip and causes horrible catches. The "pressure" from the tailstock can also be adjusted to make the safe drive more or less sensitive.
Also, for learning the skew, I'd recommend ripping a 2x4 in half. It's pine, soft and inexpensive. Start with a 12" piece of the 1 1/2" square 2x4 with planing cuts to a cylinder, using "v" cuts, lay out some beads and roll them. When that's done. Plane off the beads and do it again, then again. The soft wood is great for learning the mechanics of the skew.
If you're in the WI, MN, or IA area, email me and I'd be happy to help you out. John Lucas is an excellent "tool technician" and he's in TN.
Alan Lacer and Nick Cook both have great sites with articles available on sharpening and using the skew.
Any questions just ask.
Hope that helps,
Greg H.
