measuring thickness of large urn
Mike Nelson
>I am turning a large pot/urn about 14X16 and using my largest homemade calipers don't get a true measure at top or near bottom, only at the center. Any tricks out there that don't involve expensive lasers etc.???
Re: measuring thickness of large urn
Steven Antonucci
Ellsworth calipers
steve antonucci
>Bent wire used as a feeler. Bend a section of wire (armature wire, coat hanger- just something stiff) until it is an C shape. The distance between the two ends of the C is your reference. If it is an inch, and you insert it to a point on the vessel and see 1/2" outside while you can feel the inside touching, you have a 1/2" wall.
For the bottom, I use the same technique, but there is a d shape to the caliper. The straight part of the d is two pieces of rod in parallel. The one piece of straight rod goes inside the vessel to the bottom and the curved section is outside. When the caliper is closed, both ends of the parallel rods are the same length at the top. When inside, they are different by the thickness of the bottom and measured at the end by the difference.
I couldn't find a picture, and I think I scavenged the steel for another project. Hope the description isn't too cryptic...
Steven
Re: Ellsworth calipers
Mike Nelson
>Thanks Steve, I knew I heard something about stiff wire, not sure what you mean about the bottom but this should help me with the top. I want to get this piece of Maple to about 1/2".
Steven Antonucci
Quick and dirty drawing
steve antonucci
>When you "close" these, the two rods touch at the top and the bottoms are even. Mine is two pieces. Works well.
S
ebd
Re: measuring thickness of large urn *LINK*
ebd
>Take a look here:
Link to how to make
Steven Antonucci
I knew I had seen it here first!
steve antonucci
>Thanks for reposting this. Mine is nowhere near as pretty as yours is, but I might just have to make another one. I don't make the leg on the bent section as long as yours is, and I turned a small button on the back of the straight rod to have something to grab onto.
Steven
jim miles
Jim Miles
>Another method: drill hole through side wall of vessel with the smallest bit you have. Stick wire through - get good reading of thickness. Fill hole when done, if highly figured wood, you'll never see hole.
Mike Nelson
>Thanks! I knew there was a easy way, just couldn't remember!
