Sand blasting equip. *LINK*
Mike Cunningham
>Does anyone here have experience with sandblasting equipment and able to comment on the unit featured in the attachment.
It has a decent size cabinet area, two guns and since my wife has had positive experiences purchasing glass equipment from them I think the quality (at that price point) is there.
Thanks,
Mike
Delphi
Re: Sand blasting equip. *LINK*
Bill Crommett
>Mike: Looks like a class product. I made my own for about $48.00 using scrap OSB, some K Mark kitchen gloves and a piece of window plastic that was laying around. The only expense was for the ceramic spray nozzle. I never needed a pencil nozzle so that is missing.
Mike Cunningham
>Thank you for your comments...........now you've got me thinking of a DIY!
Ceramic Nozzle
Al Neighbors
>Bill, what's the approx cost of a ceramic spray nozzle...? I've never seen any of these things, but seeing all those Ash pieces that have been sandblasted, makes me want to give it a try.
Correction: I remember seeing a man cleaning spark plugs in something at a mechanics shop once... but don't think it was like the one pictured in Mike's post..
sand blasters
>Northern Tool has a kit with ceramic nozzles for about $50. Replacement nozzles are available. For casual sandblasting, you can get a cheaper gun with a ceramic nozzle from Sears or HD that has a pickup hose you stick into a bag of sand, about $25 or so. Another option is an inexpensive sandblasting gun with a can that looks like a paint gun. I bought one of these years ago and used it a lot.
The problem with the low end sandblasters is they can be pretty slow to remove material such as paint and rust and wood. You need a big compressor and a high volume delivery system to work fast but this shouldn't matter much for playing around. BTW, I once worked where piping was prepared for nuclear reactor construction - they used a sandblaster with a nozzle that must have been 1.5" in diameter. I was told it could take the flesh off your leg down to the bone in an instant. The workers dressed in protective suits before entering the sandblasting bay. The railroad ties used to block up piping assemblies for sandblasting were turned into fantastic artwork in a very short time!
You don't really need a sandblasting cabinet or booth for casual use. A big cardboard box out in the driveway works fine if you want to collect the sand for reuse. Don't do this in the shop or you will have a big mess. Good eye and lung protection from the dust are a must.
The spark plug cleaners have a small jet nozzle and are pretty weak in comparison to a sandblaster. Those I've seen would take a long time to do something useful with wood. I made one with a hopper that I've used with silicon carbide grit for both spark plugs and for glass "etching".
Re: Sand blasting equip. (long)
Pascal Oudet near Grenoble, Fr
>hello,
like others have said, this is intended for glass, you don't probably need to invest in it right now and I'm not even sure it will fit your need.
if you want to try sandblasting, make your own cabinet from a cheap transparent plastic box (as big as possible), the lid should lock in place so that it is more or less hermetic. 2*4" holes with long plastic gloves hermetically attached, one input hole for compressed air, one output hole to connect your vacuum (a good one, with fine dust filtration, not a dust collector. I use a festool CT22). and a few holes as additional air input, because your dust collector will pull more air than what comes out from the sandblasting gun (so no dust can escape). the abrasive will stay in the box. for the gun, a cheap one will work. ceramic nozzle will work longer. carbide are best. a good deal is the Speedblaster gun, it has its own tank for the abrasive and doesn't need much air flow.
after several hours the plastic will not be transparent anymore, upgrage by making a new hole for a plastic window (protect it with saran wrap that you can regularly replace)
that's how I started.
once you're hooked on sandblasting, you can build a bigger cabinet. I made one with plywood, 3ft*3ft*27". again, holes for gloves and so on.
then you can upgrade to a dedicated dust collector with special cyclone to separate dust from abrasive (usuefull with fine abrasive). at this point, it means you're really serious into sandblasting.
oh btw, one important point: you need a BIG compressor, with plenty of airflow. that's where you need to start. I started with a 3HP 29cfm and almost killed it after years of extensive blasting.
I now have a 5HP, 43m3/h (that should be 73cfm if my conversion is correct) compressor.
attached is a sandblasted piece (called "the nest") that I donated to the AAW auction. as you can see on the inside, the "nest" is sandblasted through.
Pascal
Thanks Pascal, very interesting and useful
