Vacuum Kiln Wood Drying
BobM
>I got this email regarding a book about using and making a Vacuum Kiln for drying wood. Does anybody know anything about this or have any experience with Vacuum Kiln Wood Drying?
This is the email.
"I want to let you know about a book likely to be of interest to your club members. �Vacuum Kiln Drying for Woodworkers� shows you how to build and use a vacuum kiln for drying wood. It also explains about wood drying in general (always a hot topic at meetings!) and the advantages of using a vacuum kiln over other methods.
I am offering free shipping for AAW club library orders received through August when purchased through this link:
http://www.vacuumkilndrying.com/aaw.
In addition to your club library book order, I will include as many copies as you would like for your other club members in the same envelope, also with free shipping. Check out VacuumKilnDrying.com for more info and feelfree to contact me if you have any questions.
Regards,
Josh Salesin, author
AAW Member � San Jose, CA
I'm not trying to promote the book and don't have any affiliation with the author. I'm just trying to find out if this works and anybody's experience with this process.
Thanks in advance for your input.
Re: Vacuum Kiln Wood Drying
>Yes, it works quite nicely. With or without a heat source.
I used to work for a company which made wood flooring. They drew a fairly high vacuum on batches of flooring to dry it out. They then impregnated it with methyl methacrylate monomer (and dye) and polymerized the MMA monomer. Water really interfered with the polymerization process. We had to run test batches on each lot of flooring to see how long it would take to get it "dry". Of course, we got it a lot drier than you would need to. You'd be wanting 6-7% EMC, we tried to get it a lot drier (and we were starting with kiln-dried).
robo hippy
>There is a vacuum kiln locally, and I have gotten some wood from it. I prefer it to 'kill' dried wood. Madrone is one of our local woods, and if you are familiar with it, it is extremely difficult to dry with out a lot of movement, as in shrinkage, cup, warp, twist, and cracking. The vacuum kiln does an excellente job. It keeps color better, and the wood works more like air dried wood than kiln dried wood. I did rip one big leaf maple board, and got zero deflection/spring,
robo hippy
Rob Wallace
Rob Wallace
>I also would like to know if people have experience in vacuum drying roughed-out (green) bowls with vacuum kilning. I have a vacuum chamber rescued from a piece of lab equipment, and a high-vacuum pump from an old electron microscope. I am toying with the idea of building a 'bowl scale" vacuum kiln (Question...is heat really necessary?) and would like to know if others have already been down that road before.... ... does anyone have experience with vacuum-drying bowls?
Rob Wallace
robo hippy
>I remember a thread on this on one forum, but can't remember which one, maybe AAW. Guy built a chamber, and used a light bulb for heat source. It was a presentation for a club. I don't remember a result for his bowls, but the heat does help, and the vapor does exit some how. Sorry so vague, but it was within the last year, and I would also be interested in if it works, and if it is practicle. One bowl at a time wouldn't work for me, but 30 to 50 would.
robo hippy
