Jet mini making noise....
Mark Williamson
>Hey, I have a Jet mini lathe that is about 3 maybe 4 years old at the most. It just recently started making a "clicking" noise at the headstock that seems to be getting louder as the days go by. I would assume that is a bearing under the pully wheel? Is this something that normally happens over time or have I done something to cause this problem by neglect? I do take pretty good care to keep it clean. I don't know if this is something that should be included in some type of scheduled maintenance or something, regreasing the bearings? Is this something that is relatively easy to fix? In need of some guidance! Thanks
Mark
Re: Jet mini making noise....
Greg Haugen
>Mark,
How close are you to a "jet" dealer and service shop? Here's a link to help find one. http://woodworking.jettools.com/Locate.aspx
Depending on when you got the lathe, Jet has a five year warranty now. It could still be a warranty issue.
Now with that said the most common "cause" for a clicking noise are loose set screws. The shaft that the pulley's are on has flats on it and the set screws tighten to those flats. In the event that they loosen from vibration the pulley will start to "rotate" on the shaft and the "Clicking" noise is the tip of the screw coming back around and hitting the other side of the flat. Check all of the set screws on the pulley's and double check your pulley's are still in-line.
Bearings are usually a higher pitched screech.
Hope that Helps,
Greg H.
Re: Jet mini making noise.... *LINK*
Dick Coers
>It's a pretty common problem. They are sealed bearings, no lube needed. You did nothing wrong, it just happens. Did a quick google and found some instructions for you.
bearing replacement
>Check 2 things first. The handwheel comes loose on those and this holds the spindle shaft in place. Loosen the set screws and the screw the handwheel on until there isn't any slop in the spindle. Then check the set screws in the pulley. If all of those are OK then you might have a bearing problem. The shaft can be pulled by removing the handwheel. You can find the bearings locally they aren't an odd size.
Greg Haugen
>Oh Yeah. Good tip John. I forgot about the Hand wheel loosening up.
Checking those areas and their set screws should be the first step. If the problem isn't found then go from there to the bearings.
Good Luck.
Greg H.
Mark Williamson
>HEY! THANKS!!! I finally got a chance to get out there and chceck it out. It was in fact a loose set screw on the pulley! And to think, I was starting to think I was going to be without a lathe and it was going to cost a fortune to get it fixed! That is great! Thank you all for your advise/knowledge!
Mark
