>After seeing a demonstration at the AAW symposium, I am interested in putting some straight and spiral flutes on some bowls and vessels, maybe even small fluting on some boxes. Can anyone tell me where I can find some instruction and guidance on this. I found an article in Woodturning Design, but am looking for more. Thanks in advance for your help.
>Bob There are lots of ways to do fluting. My article on making a fluted box in Woodturning Design should give you a pretty good idea how to do lines in a vessel with a router.
If you get the book techniques of spiral work by Stewart Mortimer it will answer the layout questions and how to cut spirals with hand tools. I've done it with just a cabinet makers rasp. The typical way is to start with a handsaw to cut the depth and then clean up the shapes with a gouge or chisel.
John Jordan is one of the best at fluting a vessel by hand. I know he has some turning videos but I don't know for sure if teaches that in one of them. It's been a long time since I've seen them.
I just watched a video on fluting wooden vessels using die grinders and flex shaft machines but I think it's out of print. I checked it out from our club and them tried to find it on the web and it didn't exist. Sorry I can't remember who did it or the name. He uses a sled in the banjo the same way I use the router but instead of the router he uses air grinders with sanding drums in them.
