200+ woodworking book reviews
Duo Lathe made in Chicago
Larry Hamon
>I am looking at getting a DUO lathe from a relative. It appears to be ;very heavy duty, and was made in Chicago. Is it worth my time? I have never heard of it.
some people think that it is American made so it must be the best.
I would appriciate any help.
Thanks... Larry
Re: Duo Lathe made in Chicago
>It looks somewhat like any number of lathes that I've seen from the 40's and 50's. It should be pretty decent as long as the thread sizes and morse tapers are a common size. Most of those I've seen had #2 morse tapers with 1"x8 threads but I know there were some oddballs. I've forgotten the name of the one I used for several years, it wasn't Duo but it looked the same.
Don Evans
>It's possible that this was a metal lathe/wood lathe. The clue is to look close at the bottom of the tailstock in the picture and note that it has a "v" notch in it that rides an inverted "v" in the front way. Metal lathes use this to keep the tailstock aligned with the head. It's then a simple matter of removing the saddle/apron assemble from the lathe and put a tool rest on it for wood working.
There is a company located in Chicago that made Logan lathes and also the same lathe (some of them) sold under the Montgomery Ward name back in the 1940. I've got a Logan metal lathe from 1945 and it is a great well made lathe for home and small shop work. I don't turn wood on it, have 2436 for that but do play with metal work some.
Logan is still in business and still sells parts but this Duo may be a knock off and parts may work, who knows at this point.
Anyway, check out the link for Logan and there is other information there and check out their links.
Don
Don Evans
>I just took another look at the picture enlarged and note there is no "lead screw" on the front of it running the length of the ways or bed, what that tells me is this lathe was made for wood working only, not metal.
It's sort of looks like a pieced together lathe from a logan bed, delta head stock and logan tailstock. Or others names like southbend tailstock. Point is Chicago tells me Logan did it perhaps for someone else, like they did the Montgomery Ward lathes.
Let us know what you fine!
Don
Keith Tompkins
Keith Tompkins
>Larry, you can never have too many lathes. Looks like a good machine, but then I'm a sucker for old American iron.
Re: Duo Lathe made in Chicago *LINK*
Don Evans
>I just realized the link didn't show up for Logan. Sorry bout that, I used the optional link boxes, they have always worked before.
Here it is:
http://www.loganact.com
Don
Logan Lathe in Chicago
Texadian
>The Brand name is Duro, yes it was made in Chicago about 1950. I've been using one for many years. The inverted vee ridge on the bed and corresponding notch in the head and tailstock insure that the centers will align perfectly. It has #2 Morse Tapers both head and tail.
No tools required to adjust tool rest or tailstock, has a nicely weighted handwheel on the tailstock.
The only problem with this lathe is 7 X 1 1/8" spindle threads, RH for inboard end, LH for outboard end. Nobody makes attachments with these threads. Fortunately, when I bought mine, it had two inboard and one outboard faceplate. To accomodate attachments with 8 X 1" threads, I bought a #2 Morsetaper stud and had threads machined on it. The stub is bored and tapped at the small end so I can use a piece of threaded rod and nut to hold it in the spindle.
I think it is a good lathe and will serve you well till you need variable speed, reversing, digital speed readout etc.
