Supernova #2 chuck
Supernova #2 chuck
Supernova #2 chuck
Jim Pittman
>I have been seeing some good deals on different packages on the supernova #2.I have never used one are they a good chuck? (pro or con) Thanks Jim
Re: Supernova #2 chuck
Brad Vietje
Great Chuck.
Brad Vietje
>Jim,
I started with a Supernova, got a Oneway Stronghold, and bought a SuperNova-2 for a club lathe. While I now use the Stronghold on my Powermatic, and the S-N on a Nova Comet mini lathe, I have used the S-N-2 enough to like it a lot. Which chuck would be best for you may depend on what sort of turning you do.
My issue with the original SuperNova is the chuck key, which doesn't register positively in the scroll gearing very well, and needs to be jiggled a bit to get it to seat well for tightening or loosening operations. This flaw was completely eradicated with the release of the S-N-2. The S-N-2 is not as big and massive as the Stronghold, but in my view, entirely on Par with the Oneway Talon. One feature I really like in the Nova chuck line is the interchangeable jaw sets -- no so with Oneway. That said, the Oneway #2 Profile jaws may be the best all-'round jaw set on the market for general turning. Again, YMMV, and the best chuck and jaw set(s) option for you may depend on the type of turning you do.
Safe spinning,
Brad Vietje
Newbury, VT
Tommy Holmes
>Teknatool's chucks are all I have ever used but I have been very happy with them. They have a nice variety of jaws which are interchangeable between their chucks and inserts are used to fit different lathes which is cost effective if you upgrade to your lathe. They grip and hold very well. The only quirk about them is that they tighten when you twist counter clockwise but I've not had any trouble adjusting to.
Steven Antonucci
Agree 100%
steve antonucci
Jorge Castaneda~Downeast Maine
>Jim,
SN2 is a good chuck for general use, for big stuff go to the Stronghold.
As already mentioned it tightens and loosens the opposite way from what we are used to, there are quite a variety of jaws available for it, a safety feature of it is that the jaws do not protrude from the body of the chuck (so it will not hit your knuckles) the down side is that because of this, the range between the smaller and larger openings of a set of jaws, is rather small, forcing you to own more jaws and the nuisance time from having to change jaws when you are in a roll.
Hope this helps
Jorge
Jerry McCaffrey
>I've been using the Teknatools G3 for several years & was impressed enough with it to get the Titan (which was on sale @ Lee Valley) for my bigger lathe. It seems to compare very favorably with the Stronghold. Recently I got a good deal on a SuperNova2, so I now have the entire line. I've only used the SN2 for one project but it was a pleasure to use. The hex keys used for tightening on the Titan and SN2 are great. Be aware rumor has it the Teknatool is offshoring their production fron New Zealand to China. All of my chucks are prominently marked "Made in NZ." The counterclockwise tightening may be a southern hemisphere thing, but you get used to it
I like it.
Brian Hahn in SW Wisconsin
>I started out with the original Nova chuck 12 years ago and I still use it. I added the original Super Nova a little later (don't use it any more). When I got a new lathe (Robust) last fall, I expanded my chuck inventory with two SN2's and two Titans.
I use the SN2's most of the time. Having the same jaws work on all of my chucks is a real advantage.
Bill Blasic
Re: I like it.
Bill Blasic
>I received one of the first Chinese version of the SN2 and tested it against a NZ version and after comparing everything that I could check. I found all dimentions, runout, etc. were the same on both chucks. Seeing that the machine used to make these chucks was sent to China (I was told) I'm not surprised as to the results. I use the Nova chucks almost exclusively because that is what I started with and I have had no problems with them.
Love mine
Steven Kubien
>I've got 2 supernova 2's (and a Nova Midi) and I really like them. The only dismounts I have had were operator error (too big a bowl on too small jaws). Lots of jaws which are interchangeable which is good. The tightening/loosening directional thing is easy to get over because there are arrows on the chucks. If I end up getting a larger chuck down the road, I will not hesitate to get the larger Nova (whatever it is called).
Steve Kubien
Ajax, Ontario
Re: Supernova #2 chuck *LINK*
Fred Holder
>With all of the positive posts, my message is pretty much unnecessary; however, to get my 2 cents in, I've been using Nova chucks since 1990 when I purchased my first chuck. A year later I purchased a second one. When the SuperNova came on the market I got one of those and really thought it an improvement over the two tommy bars. I purchase two more SuperNova chucks and two more Nova chucks when I was at the Canadian Woodworking show several years ago, by then I had a wife who also turns. When we went to New Zealand in 2003, the forerunner of the big chuck was on the market and I ordered one for pick up when we got to New Zealand. I later purchased the three screw version of that chuck. Then when the SuperNova 2 came on the market I purchased two of those. I purchased one of the G3 chucks when they came on the market to use on my Nova Mercury. You would think that I'm a chuckaholic and I think that is the case; however, I hate to have to change jaws and Mildred is the same. The SuperNova 2 is the best of the smaller Nova Chucks in my opinion. The only other chucks that I own are two small Vicmarc chucks (one for each of us), which are also hard to beat. I would say go for the good deal, you'll not regret it.
More Woodturning Website
chuckaholics anonymous
>>...You would think that I'm a chuckaholic
If you find where the chuchaholics meet, let me know. I think I'm up to 11 chucks so if they have a 12-step program for people like us I'd better run out and buy another chuck first. Some are Supernova, some Supernova 2, and a couple are the smaller chucks (forgot the model name).
With the pinion gears inside the Supernova 2 chuck instead of on the key, the problem of aligning the key on the Supernova is eliminated, although I never really have a problem with that if I peek around the back when inserting the key.
I'm with you on the jaw changing - it is so much easier to work with a chuck for each set of jaws. I hate to admit it in public, but I even have some chucks with duplicates of my favorite jaws so I can leave work attached while working on another piece. This is especially handy when I want to start on another box while letting the first one stabilize overnight before fitting the lid.
