REAL MILK PAINT
proper bevel angle?
proper bevel angle?
richie croce
proper bevel angle?
richie croce
>anybody know the proper bevel angle on the ellsworth signature bowl gouge? Mine seems to have fallen off during my percice attempt at sharpening.
Re: proper bevel angle?
Don at Central Illinois
>I'm at work now, but if you got the video, it will tell you wha the angle is and why. I'll try to look it up this evening, unless someone else answers you befor I get there.
60 degrees
Bruce Lane
richie
>I watched that video 6or 7 times. No mention of angle. Whent as far as pausing tape when a close up of gauge was presented and put my angle finder on tv screen. Got about 45 degrees. I hope that its right but would still like to know for sure before I preform next grinding.
I believe it's 62 degrees
55 to 65 degrees per David Ellsworth
Russ Fairfield
>Read about the Ellsworth Grind in the Grinds Library available in Odds and Ends in the side bar of the Index page.
Davids instructions say 60-degrees, but he also says that is the middle of a useful range of 55 to 65, and it is up to the user to determine the differences and which one they like the best.
The difference between this and some of the other tool profiles is that the same angle is maintained between the bevel and the inside of the flute from the tip all the way along the side grind.
Re: 55 to 65 degrees per David Ellsworth
richie c
>thank you all for your help.
>Since we had so many responses, I didn't look at the DVD, but now you've piqued my curiosity and will have to drag it out and see. I thought for sure he mentioned the proper angles.
Peter Charles Fagg (UK)
