Finishing Holly
Finishing Holly
Finishing Holly
keith zimmerman, Normal, IL
>I'm getting ready to turn my first finials out of holly and was wondering if those of you that have turned holly before would share how to finish it to retain the white color, if possible. The holly I have is over two years old and is white with no staining.
Also, when I turn this finial, I want to turn it endgrain. How do you determine which way the grain runs, or does it matter?
Thanks in advance.
keithz
Re: Finishing Holly
Re: Finishing Holly
Russ Fairfield
>There is nothing like Holly to prove that all finishes will add something to the wood, and that all finishes will turn orange with age. The only way I know to keep Holly white white is to put nothing on it. Sometimes the wood itself will age to the slightly amber color of old ivory, but sometimes it will stay white for years. A coat of carnauba wax will add the least color to the wood. Krylon workable fixitif, used alone or followed with Krylon lacquer for a higher gloss, will add the least color of any real finish that I know of. You will have to accept the it will not stay white with everything else.
Re: Finishing Holly
Re: Finishing Holly
Gary Ljostad
>Keith, when I use Holly, I almost always bleach it, to get it white as I can. The only finish I use than is lacquer sanding sealer. I have pieces that I did 4 years ago that are still very white. No yellowing yet, but time will tell.
Re: Finishing Holly
Keith Tompkins
Re: Finishing Holly
Keith Tompkins
>HI Keith, I wouldn't suggest turning it end grain...it will be a weak finial, and the tooling won't be as clean. If in doubt, cut off a small slice of wood, and split it with a chisel...it will split along the grain.
Re: Finishing Holly
Re: Finishing Holly
Nick
>I recently finished some holly with minwax wipe-on polyurethane. This stuff is very clear-only slightly yellow. The clearest finish I know of is water-based acrylic varnish. This stuff is dead clear-no yellow but I don't know about long term.
Re: Finishing Holly
Re: Finishing Holly
Steve Worcester
>I got some Hydrocote Resithane Pls pre-cat water based lacquer that I have used on bleached turnings and it works well, has to be sprayed though.
Automotive clears will work also, but a much steeper learning curve and physicallt nasty to work with. But they dry harder and tough, usually with a UV protectant too.
Re: Finishing Holly
Re: Finishing Holly
Scott Hurley in N. VA
>I've had some luck with General Finishes Salad Bowl Finish - it doesn't seem to have much color at all...
Scott
Re: Finishing Holly
Re: General Finishes High Performance...
Jamie Donaldson
>... is a water based finish that dries water clear, and I have liked the results on maple and other light colored wood without any trace of yellowing.
Re: Finishing Holly
ivory look
>Kieth,
I've turned several wands and finials for ornaments from holly. After some experimentation, my favorite finish is the shellac-based Mylands Friction polish. Like almost every finish, it does change the color a bit. However, I've had several people tell me the result looked just like ivory.
The handle in the picture was carved and darkened with a paste filler.
Re: Finishing Holly
Steven Antonucci
Sweet!
steve antonucci
