My Priddle burning pen
steve antonucci
>I've been branding pieces with a handheld torch and brand for a while now, but after meeting Graeme Priddle a few weeks back, I decided to build his burning pen. Being somewhat frugal, I decided that I wanted to build it without messing up my battery charger.
In reviewing his design, it's actually pretty easy to build one without cutting up a charger. I had some 12-2 laying around, bought a plug, a dimmer and some terminal blocks and off I went. I actually shorted the first dimmer out accidentally, so I did it twice. The second time was a charm.
In essence, all he does is lower the voltage on the charger by cutting the dimmer into the input feed. I simply wired an outlet with a dimmer and plugged the charger in there. Tested it with a lamp to verify that there were no shorts.
His pen is pretty simple too. I turned mine out of some curly birch dowel I had laying around. I quickly cut out a small recess for the terminal blocks (from Radio Shack) and ran some lampcord through to the terminal block. Finally, I connected the other end of the lampcord to the electrical terminal pictured. Everything is mounted on MDF.
The use of the burner is very simple. Plug the "burner board" in to the wall. Plug the charger into the burner board and turn it on. No current until the dimmer is opened. The two "jumper terminals" on my battery charger simply get connected to the lampcord terminals. I need to get some Nichrome wire, but for the interim, I have armature wire as a tip. The whole thing is meant to be clamped to the lathe tool rest (or similar) with the charger sitting on the floor.
I turned it on, and I have to say that the "buzzing" in my hand from the wire heating up was a bit disconcerting, but man does it fry wood! As Graeme Priddle mentioned, the heat recovery time is unbeatable. This freakin thing screams! I've attached a second picture from the inaugural test flight.
Thanks for looking.
Steven
