Re: System 3 Epoxy
Chuck Engstrom
>Hi Tommy -- Your choice of thickener depends on what you want the epoxy/thickener combination to do. My general practices go like this:
silica thickener: use when you want to thicken the epoxy so that it doesn't run. Most epoxy "glues" probably use this (also called Cabosil) as an additive to make somewhat liquid epoxy become a thixotropic paste.
micro balloons: use these light-weight tiny tiny plastic bubbles to create a putty for filling cracks, dings, etc to fair up a surface. They do not provide much strength at all and should be avoided when strength is an important issue. Sands easily, usually the main reason to use it.
wood flour: can be used to give some color to your mix. I've saved little jars of several wood sanding dust to use this way -- cherry, walnut, teak, etc. Coffee grounds will give you a pretty good imitation of most dark-colored tree barks. Not terribly strong.
West System, another supplier of many epoxy products, has a chart for selecting fillers at http://westsystem.com/webpages/productinfo/guide/index.htm#fillers. Their stuff is compatible with System Three epoxies.
I have used System Three for many years and measure it out with an old pair of large-sized hypodermics, one 60cc the other 30cc. This method allows you to mix only as much as you need -- I can mix up as little as 2cc resin and 1cc hardener with reliable success. Epoxy has never been cheap, and with oil now over $140, I hate to think of wasting any. Shelf life, by the way, is virtually unlimited: the S3 stuff I am using these days was given to me about twenty years ago and still works fine.
