>At one time I was planning to try turning a bowl larger than the capacity of my lathe by using the outboard side of the spindle. In anticipation of this, I had an insert made for my Vicmarc chuck made with a LH thread, so it would fit on the outboard side of my spindle.
Then I figured out that even though the insert had a LH thread, the thread that holds the insert onto the chuck is still a RH thread, which means that it's still going to cause a disaster one day if I try to use the chuck on the outboard side.
I do have a faceplate with a LH thread that goes on the outboard side of my lathe. What I'd like to know is, are there any directions out on the internet that show how to make a bowl when all you have is a faceplate?
[I know, the correct answer is "Buy a bigger lathe." Still saving up for that.]
>Did you check your manual? Many lathe manuals have a short description.
My personal preferences are to mount a glue block on the faceplate (poplar, pine or less expensive wood) with screws (short wood screws - don't use drywall screws). Smooth the face and round the corners. Glue your piece to the glue block. Turn.
At the end, turn it off (very carefully) or cut it off.
>If you are worried about the chuck insert backing out, install grub screws in the side which will bite against the threads holding the insert in place. This will prevent the chuck from unscrewing itself when used outboard or when used inboard with the lathe running in reverse. Some brands of chucks come from the factory with these tapped holes already machined.
>Use a faceplate to get your shape and hollow the inside. Then, put the bowl inside a doughnut chuck to finish the foot. (AKA Straka chuck, I think...)
For me, the biggest challenge in turning bigger then the swing over the ways is reach and support for tooling. The headstock on my Nova will swing and turn as big as I care to, but I get stuck reaching the wood with the tool. Either the tool is too far over the rest or the rest can't reach the spot I need to turn at all. BTW- This often happens as much as 1" over the 16" swing. For the most part, I just turn 15.5" nowadays to avoid it...
>I wrote the following information on this subject in the May 2002 issue of More Woodturning. I hope it helps answer your question>
Chucks are wonderful time savers, but are not necessary to turn wooden shapes such as bowls and hollow forms. In fact many woodturners mount all of these shapes on faceplates and turn the entire vessel on a single mounting then use some form of home made jam chuck to turn the foot after the bowl is completely turned. Even though I have a number of chucks, I often use a jam chuck instead of a chuck. This is especially true when turning very small bowls such as pill bowls, which may measure 2" across at the top.
To use the mounting stuff that comes with your lathe (i.e., faceplate, drive center, and live tailcenter), here is the way to do it:
1) Mount the bowl blank between centers, but with the grain of the wood being perpendicular to the axis of rotation and the planned foot of the bowl toward the tailstock center. Balance it as well as possible and run the lathe at its minimum speed. Start small first (4" to 6" in diameter).
2) With the bowl blank mounted between centers, turn the outside of the bowl to shape and turn a foot for the bowl. Don't make the foot too small on your first few bowls, leave them around 1/3 of the diameter, a nice functional size. Leave the tail center mark in the foot; i.e., don't turn it away. You can turn the bottom of the foot so that it will have a flat area to fit into a jam fit chuck, but leave a little tenon in the center with the center point in it. You'll need that later. Sand and finish the outside of the bowl.
3) Remove the bowl from the lathe and mount the faceplate with a piece of scrap wood mounted on it. Turn the face of the wood nice and flat. Then turn a recess in the center that is deep enough to bottom the turned foot of the bowl and bring the bottom surface of the bowl shape to touch the top of the scrap piece, but still small enough that you cannot slip the foot into the recess. You will have to cut a deeper recess in the center to accept the center tenon you left on to retain the center in the foot. In case you get it a tiny bit too large, i.e., a slip fit, you can sometimes take up a part of the space with a paper towel.
4) When the recess is almost large enough to accept the bowl blank, Place the foot against the recess and bring up the tailstock. Apply pressure with the tailstock. Then with a mallet, tap around the top of the bowl while increasing pressure with the tailstock. If you were close enough to size, your foot should be able to be pressed into the recess until the top of the scrap piece touches the bowl. Turn the bowl by hand to check for run-out. Turn on the lathe, again at its slowest speed and check for run-out by touching the finished outside surface of the bowl along the bottom side of the bowl. If it seems to be acceptable great, it is unlikely that you'll get it perfect the first few times. Again practice makes perfect, lots of practice.
5) Now, with the tail center still in the top of the bowl, start hollowing. Leave the tailstock in as long as possible and turn so that you have a little column 1/2" to 1" in diameter in the center of the bowl. If possible, turn the bowl to final depth with this column still in the center. Then break off the column, move the tailstock out of the way and sand and finish the bowl inside. At this point, your bowl is completely finished inside and outside, except for the foot.
6) You can generally remove the bowl from the waste block by applying pulling force on the bowl, but not enough to break it, while tapping the waste block with a mallet. Don't tap too hard or pull too hard. If it will not come loose, you can likely part away the waste block until the bowl comes free.
7) Now mount a piece of wood on the faceplate so that it will give you a disk that is larger than the diameter of your bowl. Turn a recess that your bowl lip will snuggly fit into. It is best if this recess is a snug enough fit that you can press the bowl into it with a good friction fit. Now, bring up the tailstock to hold the bowl securely in this new jam-fit chuck. Turn the foot to final form, leaving a little tenon in the center for the tailstock, sand and apply finish. If the mounting in the jam fit chuck is secure enough, you can back off the tailstock and gently turn away the little tenon, sand and finish.
8) Remove the finished bowl from the jam fit chuck by applying pulling pressure while tapping the jam fit chuck with a mallet. With luck it will pop out without any damage. Sign the bottom with a permanent ink pen like the Sharpie and pat yourself on the back. Then share your treasure with your spouse or a friend or someone else in the family.
Remember, I said practice, practice. So don't expect the first one to go perfect. The technique that I've just described I have used many times successfully and know that it works. Start small and learn a lot with each attempt.
>HI Wilbur, another way to turn a bowl outboard is to use a large faceplate, the mounting screws will be secured to the blank by wood that will later be turned away when the bowl is reverse-turned, leaving no screw holes in the finished piece. That's a method David Ellsworth demonstrates.
