>I just came from Woodcraftand they have a new sanding system comming out. They are Scotch Brite balls in 4 grits on shafts. The look like they would be great for sanding small bowls and hollow forms. The only trouble I see is how small a opening can they go through.
The guy at Woodcraft told me they should be out in a month or so. There goes more money out of my pocket.
>I look forward to seeing this product. I am using a homemade version of that by cutting discs of varying sizes out of the different grits of Scotchbrite pads. Then I use my small velcro/hook and loop disc holder to hold these discs to help me sand the bottom interior of boxes and up the sides of more rounded forms.
I would like someone to develop a way to mount these Scotchbrite sections more securely to the disc holder. Perhaps a holder could be developed with more pronounced hooks.
I always use the various grits of Scotchbrite pads as part of my sanding process. The total randomness of the scratch pattern helps scratches from sandpaper disappear. I should say I am not actually using the Scotchbrite brand but a similar product that I purchase from Klingspor.
>I've drooled over something similar. Bruce Hoover of thesandingglove fame now sells the Gwenevere sanding system. I looked at the round sanding heads and they can be bought seperately with the inflator pump if you already have a flex shaft machine. I may break down and just buy the whole set up. It sure would be handy.
Click on the website and then on the PDF catalog page and go to page 21 (or was it 23) anyway I'm pretty sure he sells the balls, sanding pads and pump as a seperate item.
>Hi folks -- Dremel provides a couple of Scotchbrite-like items, see link, but they may not have the shape or grit you're looking for. They're about 1-inch diameter by 1/2" high and fit on a mandrel, #402 I think.
>These do work but they wear down really fast. I use them for carving because the follow the curve of the work but I'm a little dissappointed how quickly they wear out.
It would be good to keep in mind that as well as being a completely random abrasive distribution, there does seem to be a slightly random particle size distribution, too. While I use these pads quite a bit, and generally like them, they can result in scratches occasionally. I suspect it isn't a lack of uniformity in the actual abrasive particle size, but more likely a clumping effect that results in some bigger abrasive "bits", and an occasional scratch that can be annoying and take extra work to remove.
