Paulownia Pitcher Practise Piece
Mike Jones, Redding, CA
>I have turned several pitcher forms and constructed/glued handles to them. The form intrigues me, but I was never satisfied with the attached handles. This form was constructed from a paulownia plank.
Soft, horrible tear-out, but easy to carve and sand. (like balsa).
Three 14 inch lengths of 2 x 6 were laminated with newspaper sandwiched and a basic vase form turned, outside only. After deconstructing the form, a fourth piece was cut on the bandsaw using the outer pieces as a template, and with the handle shape added. The inside of the handle cut out with coping saw and the shape of it improved with micro-file and sandpaper.
When all glued back together, the interior was turned, and the sloping neck cut to make a pitcher out of it.
I made several critical errors in the process, but finished with dyed lacquer sanding sealer, it was, at least, a successful first attempt.
Photographers please leave me alone...All other critiques welcome!
