Re: Cast Iron Radiator Handles
Rick Allen
>I would use something hard. Brazilian Cherry comes to mind as a good choice.
If you can put an insert in to take the wear of the square fit then many other woods start to look like good options.
You could make the insert out of Brazilian Cherry. I would make the insert square. So a piece of Brazilian Cherry that is 1 1/2" square with a 3/4" square hole in the middle for fitting over the radiator valve. If the insert is going to show through the "wheel" wood you might want to have the "squares" 45 degrees out of sync just for looks.
A ball or dome shaped "wheel" might be nice. Drill some 3/8" holes around the "wheel" and fill the holes with a contrasting wood could give a nice effect.
Sounds like a fun project.
