>I just cut up a branch that fell off of an apple tree in my yard. I have never turned apple wood before. Is there anything that I should or should not do to it? The branch was about 10" in diam. at the widest part so I am planning to turn a couple of small bowls maybe a lidden box or two and the rest in pens. Man I love free wood!!!
>Well since Apple is obviously a fruit wood, it's a little prone to cracking/checking as it dries. Care should be taken in the drying process. Just seems apple and cherry practically start cracking/checking before they hit the ground. Gorgeous wood to turn!! Especially for natural edge bowls, etc. If it does crack or anything happens to it so it's not "turnable". Find someone who "smokes" BBQ meat. They love to use apple and cherry. It may even get you some good BBQ out of it. :-)
I got a nice crotch section that I cut into halves and roughed them out and applied anchorseal to all surfaces. A year later and they warped and cracked so bad they are beyond normal use for finish turning. Mulberry may even be worse but I do seem to have good luck with cherry.
Apple shrinks about as much as any common wood available, and is ESPECIALLY prone to checking as it dries.
With care and very slow drying, it can be an incredible wood to work with -- extremely fine grain and great for beads and small details. Its heavy, easy cutting, wet and smells nice when fresh; becomes quite hard when dry. Smells awful when its been hanging around too long in unseasoned log form.
