OT digital photo reduction problems
Terry Quiram, Roanoke Illinois
>I am having problems reducing the size of my digital pictures. I am taking them with my Canon EOS D30. I have the size set at the smallest format which produces pictures in the 1.2 - 1.9 MB range. After I trim them they still need to be reduced but when I go into an editor and change the pixel numbers to a smaller number the photo gets blurry. I am at my wits end. What am I doing wrong?
Terry
Re: OT digital photo reduction problems
Bill Crommett
>Terry: I use a free program called FASAT IMIGING that does nothing else but gives a copy of the foto in a 640 X 480 for the internet. It is just a click and drop program and is the most simple one I have ever seen Let me know how it works for you.
Bill
Texian
>Terry,
Might want to set the size to largest size, not smallest. You want to record the maximum amount of "information". Crop first, do brightness and other adjustments next, and resize to 640 x 480 last.
>>...Crop first, do brightness and other adjustments next, and resize to 640 x 480 last.
Good advice, but if posting to WC or for another application where the file size must be controlled, the final "last" step (after resizing to the desired size) is to save the file with the appropriate compression level (for JPG). Cropping and resizing play critical roles in reducing file size, but after that the compression level is what controls the absolute file size on the disk. I use Photoshop which makes it easy, but most image editing software programs will let you control this to some extent.
Texian
>Quite right! Left that out, as after resizing to 640x480 pixels, my file size is already down to 40 or 50K, so no need to compress it further. Depends upon the software, no doubt, as on previous computer it was indeed necessary to compress the file size.
my workflow for processing for the web
keith zimmerman, Normal, IL
>The process I use to prepare images for the web is as follows:
1. Take the photo with the largest filesize possible for the camera.
2. Open the file in your photo editor.
3. Rotate the image so the subject is straght if needed.
4. Crop the image as desired.
5. Apply your fixes, if any, including sharpening.
6. Resize the image. I like to use 500px height for vertical images and 600px wide for horizontal images as these will fit the screen on almost all computers.
7. Save the image at medium compression.
This should give you an image that is well within the limits for the web.
Hope this helps.
keithz
