shooting varnish
shooting varnish
shooting varnish
woodshredder
>I have shot quite a bit of lacquer, I found I could let the lacquer remain in the gun for as much as a few months without having problems. I have an order that will require me to shoot varnish. I've never done this before.
I'll be using McClosky's redlable spar varnish. I'm unsure as to what problems I might face, first I'm not sure how much to thin it and how often I will need to clean the gun. I'm hoping I can do several coats over a weeks time without having to go thru the entire cleaning process.
John
Re: shooting varnish
Methinks
>You hope in vain.
While lacquer thinner will redissolve itself in the gun, varnish thinners will not. Big difference between a solvent finish and a reactive one. Once the varnish dries and then polymerizes in the gun passages, you will need to soak the whole thing in stripper to break down the film. If it clogs, you'll be in for a real time cleaning the ports and things without deforming them and thus ruining their accuracy.
I have shot varnish (doors, mostly), and I used 20% naptha to thin. Naptha dries 3-4 times as past as MS so time to dust-free in much less but it does a better job of leveling the finish. You will, however, have to apply thin coats on vertical surfaces as it will slide very easily. I also try to maneuver the piece to allow me to work horizontally. I find it very difficult to work on interior surfaces.
Note on naptha: mix only what you will use in a session and do not return it to the main container. Naptha-mix will tend to jel in 10-14 days if unused. The process was described to me as "autompolymerization" but you'd have to talk to a finish chemist for an explanation. I lost a whole gallon of the stuff to this mistake.
mm
shooting varnish
Mike Nelson
>I thought varnish was thinned with denatured alchahol? I use an airless to spray cabinets with lacquer and have left it in a 5gal bucket for ever and had no problems, only way to go. Would love to do colors but hear thats a whole new ball game.
Re: DNA
>Thins and dissolves shellac, thins uncatalized epoxy resin.
Useless with oil based finishes.
Re: DNA
Mike Nelson
>I stand corrected, I was looking at some Shellac primer.
Re: DNA
>No biggie, Mike.
I made the mistake of forgetting to rinse varnish from a gun right away. It was not fun cleaning it, and I never did get it to spray as evenly as it did before. |;-{{
Texian
>John,
Ditto what they said. You will need to clean the gun thoroughly, immediately after use each time. Used to spray a lot of urethane varnish and hated the clean up hassle.
Can probably dilute 10 to 20% with mineral spirits, but need to experiment a bit as each varnish is different.
Mike Jones, Redding, CA
>Ditto and double-ditto. I shoot shellac and lacquer often. Last week I tried shooting varnish for the first time. A HUGE mistake that I will not make again. It's not just the gun that will need cleaning immediately!
But then, it WIPES ON too nicely to want to do it again, right?
Good luck with your efforts. Cover everthing...including yourself!
Re: Gun
>Definately not a good idea in a high pressure squirt. |;-}}}}
Preference would be a top-cup hlvp working at as low a pressure as you can with the material feed dialed back and as wide a fan as you can to just lay it on.
mm
Chuck Engstrom
>Hi John -- I used to use McCloskey's Man 'O War (the red label) a lot on boat brightwork, brushed on of course. It was easy to work with and gave good results, though I imagine newer products are superior in outdoor durability now. It was always more reasonably priced than some of the "marine" varnishes but just as good.
You might call McCloskey's and ask for their advice. I'm pretty sure I have seen Man O' War in spray cans, though for a big job I'm sure the price is prohibitive.
Good luck on it.
Best--
Chuck Engstrom
Russ Fairfield
>Varnishes are a lot more complex than this thread is making it. There is a whole science around the "Spirit Varnishes" which are based on shellac, have many other natural resins and oils added to them, and have properties that are much different from what we think of as shellac. They are also much a much older finish than the oil/resin varnishes that everyone is referring to here.
Forgot to Mention
Texian
>Forgot that latest procedure (like, 15 years ago), was to dilute a small amount and brush on multiple coats. After the piece was well sealed, wet sand gently w/ 600 between coats to continue sealing and leveling. Very easy to sand through to the previous coat, as it does not dissolve into the previous coat like lacquer. And finally, spray the last few coats. In those days I was going for a deep, "coated in liquid glass" look. Probably massive overkill for your project.
Re: Methinks
woodshredder
>First I'd like to thank everyone who replied, I trust your experience a lot more than mine.
My thoughts now are to brush it on and not even mention it to the customer. I would prefer to wipe it on while on the lathe but its a very odd project, first I make a bowl then I slice it up into cupboard and drawer handles. A roundover bit on all the cut edges then lots of sanding before the finish goes on. I will have a total of 80 pieces to finish but I cant afford to damage my lacquer gun over this one project.
