Sorby Deluxe Sharpening system #447
Keoni
>I'd like to get some comments and qusetions from turners who use the Sorby System. I.E.- setup for sorby bowl and spindle gouge. Seems like the finger profiler comes extremely close to the grinding wheel,I'm using a 6" grinder. Any replies would be appreciated.
Re: Sorby Deluxe Sharpening system #447
John Kyler
>Well I'm not a user yet. Also curious. I bought one, and have not installed it yet.
Jeff Rich
>I have an older Sorby sharpening system.
There are times when the tool holder does get knicked.
Depending on the grind of course.....
I grind mostly standard grinds, nothing really out there.
The system does a great job of giving you the same grind every time and the ability to adjust angles.
Cheri, the gf, likes to do some wacky grinds for her style of turning.
So far she has been able to get the grinds she wants.
I have not figured out how to do an Ellsworth grind using the Sorby, so I use the proprietary holder for that gouge.
Overall, I am very happy with Sorby system.
Keoni
>Jeff,
Did you change the factory setting of 120 deg. on the arm, is the protrution of the gouge for the factory grind on the bowl and spindle gouge (Sorby) 2" or do you adjust it to the angle? For the Ellsworth sig. gouge I had to re-adust the factory setting and adjust the protrution from the profiler according to the angle. It does not follow the instruction set up sheet. And it does come very close to the grinding wheel, what size wheel are you using,6" or 8"? Whats your experience?
Jeff Rich
>I left it at the same angle and I just match it to the bevel when grinding for the most part.
I sometimes adjust the bevel a bit, depending on what i think is appropriate at the moment.
I use 6" wheels
