home made captured hollowing tool advice
Steven Smith
>I am thinking of making a captured hollowing tool but when I went to look at steels there were a million different types to pick from and I dont know one from another. It sounded like 1144 was what I want but not sure. thanks in advance for any advice. Steve
Re: home made captured hollowing tool advice
>Steve For the captured bar all you need is cold roll steel like you get from the box stores. I've made several of them. The only part that has to be good steel is the cutters. If you want cleaner metal that slides over the tool rests better then just use some drill rod. It's moderately inexpensive and is much smoother and more accurate in sizes. However it's very hard to cut by hand.
Steven Smith
>Thanks John. Did you find a pattern somewhere or just wing it from experience?
>I went to Lyle Jamieson's site and tried to copy his first one. Then I realized that the concept behind captured bar systems is to eliminate torque so you have control. I thought you did this by having an outrigger bar of some sort or a wide H shape for the secondary tool rest. Not so. The secondary tool rest keeps the tool on the center line and this eliminates most of the torque. Consequently my second captured bar was only 6" wide instead of 10" like my first one. This is also the concept behind the Elbow tool, Kobra, and other captured bar systems before them.
i agree,john
robert davis
>my second d bar was much narrower than the first.
