If it don't feel right...STOP!
Ron McKinley
>I was in a hurry to finish turn a bowl so I could give it to a friend two days hence. I mounted it and trued up the tenon, mounted it in the chuck and realized my bowl gouge needed sharpening. I stuck it in the Vari-Grind, set the nose angle and then noticed that I had to adjust the arm out siginificantly. That was my first clue, but, being in a hurry I pressed on. I really felt uncomfortable because the gouge was too close to the center line of the wheel. Then WHAM! My Vari-Grind and Thompson bowl gouge were bouncing on the floor and I was jumping out of the way and noticed blood all over the floor.
Went inside and washed the wound with hydrogen peroxide, dried it, grabbed a Band-Aid and went back to the shop and dripped a little CA on the cut, wrapped it tightly with the Band-Aid and at that point my pride hurt more than my finger. Picked up the Vari-Grind/gouge and remembered my friend and handyman had been in my shop borrowing tools earlier and had picked up the Vari-Grind and asked what it was. I told him, but I was not paying a lot of attention, he apparently re-set the angle, laid it down and walked out.
The grinding wheel has a big chunk out of the side near the edge but the Thompson bowl gouge came through pretty much unscathed. I'll just have to re-grind it.
The moral of this story is: If it don't feel right and it don't look right, STOP! Haste makes waste and I wasted a grinding wheel, a little flesh and a lot of pride! ......Ron
