My brain thinks it has heard talk of mixing white PVA glue and water to form a solution to soak punky wood in. The purpose of this is to firm it up for finish turning. Problem is, my brain can't remember if any of this is fact or mere dillusions on its part. Needless to say, I've got a few questions.....
ratio of water-to-glue?
length of soak?
time to dry?
rough turn first, then once dry, finish turn and sand?
How effective is it?? About the same as using any of the commercial wood hardeners, and a lot less expensive. Even if you are buying the glue. Like any other wood hardener, sometimes it works and sometimes it doesn't.
A 50/50 dilution of glue with water works, but don't be too concerened with being exact. Anything close works. I use Titebond if I want the wood to be be a dark yellow, and Elmer's if I don't. There will be some discoloration of all wood, and how much depends on the wood. I use Titebond on Maple and the color is fine.
It works best for hardening dry wood. Don't expect to get much penetration into wet wood.
It can be brushed on thin wood, but thicker (up to 1") will require soaking for several days to a week to get good penetration. I soak 1" square pen blanks for a week. A little heat, no more than 150 degrees, will aid a deeper penetration, but will insure that the glue mixture can never be used a second time.
Cover the soaking pot with a Saran Wrap type plastic sheet to seal out the air. Then pour the glue mixture into gallon jugs to keep it for the next time. It has a shelf life of a couple years in a closed container.
Leave it sit for however long it takes glue to dry. It will still be "gummy" the next day, but really hard and dry will take a week. You will know whether it's dry as soon as you cut into the soaked wood. If it isn't dry, just wait another day.
You will have to give it another soak if you turn through the glue penetration.
Sanding can be a nightmare. It can be bad enough to convince you to never do this again. Remember that you are sanding glue. It melts and cloggs up the sandpaper very quickly. Keep it cool. Use slow speeds - VERY SLOW speeds. Keep that rubber eraser handy if you power sand, and plan to use a lot of sandpaper if you do it by hand.
You can use any finish on it. Give it a primer coat of shellac or lacquer if you are concerned about using a waterborne finish over glue. My experience with waterborne finishes is that they dry faster than they can soften the glue, and there is no problem with them: but they might take a little longer to dry to where they can be sanded.
>I appreciate the info. I will continue to work this piece and, hopefully, I won't need to even go this route (the wood will decide). I'm glad to have this information in my pocket.
