>For those of you that use the Woodcut bowl saver have you left the cutter in its original shape? I was using mine today and it worked pretty well on 3 bowls and a clear failure on the fourth. I was talking with a friend after he witnessed the failure and he suggested that I regrind the cutter to have a vee point. I know the Keltons and the Oneway cutters have been reshaped to have vee points. I am open to suggestions.
>I haven't reground my cutter on the Woodcut Bowl saver, but have been considering doing so. My Kelton Center Saver has the pointed cutters and works very well. I also ground my Chinese ball cutters to a "V" point with considerable better cutting and tracking into the slots cut around other holes.
I would say that it should improve the Woodcut to grind the cutters to a point.
