Veritas - Innovation in Tools
First box
First box
First box
Mitchell Cholewinski
>Hi
This is a picture of my first box, other than a couple square ones turned a while back. The wood is silver maple turned wet. Top and bottom is the same wood sprayed black then everything sealed with varnish several coats. When I turned the lid it fit perfect and closed with a pop. Now that it is drying some it is a little loose. If I keep turning wet, I will need to cut oversize a bit then fit after it dry's some.I think I should of turned the platform a larger diameter. Thanks for looking. Mitch
Re: First box
Re: First box
Barry Turner
>You wouldn't pull our legs would you? About that being your first box, I mean? Very nice! I think you will find that it's very difficult to turn boxes from green wood and have the lids fit. That just-right fit on box lids is very hard to come by, even in dry wood. You might try rough turning and letting the wood season for a few weeks, then finish. As for me, I just turn boxes from dry wood.
Re: First box
Re: First box
>Barry
Thanks and no I would not get get anything from pulling your leg. That is my first complete box. I tried one before just to see if I could make the lids fit properly and that is it. I have 3 of them turned now and I found out that wet wood needs to be rough turned and left to dry before making the finishing cuts for final fit. Just like you said. I have no trouble making them fit, in fact I was bragging to a friend how they pop together , untill they dry. This guy is great at making boxes. I am usually into deep vases,and, hollow forms, but elected to try boxes for a while. Thanks again. Mitch
Re: First box
Re: First box *LINK*
Fred Holder
>That is a beautiful job on your first box. However, wet wood is a no, no when it comes to final fitting the lid. I recommend that you never final turn a box from wet wood. Always rough turn wet wood and let it dry for several weeks before final turning.
Even when turning boxes from perfectly dry wood, I recommend rough turning the box and let it set for a few hours to adjust to the removal of wood and then final fit the lid and turn the outside. Even then, it may change when moved to a different climate from the shop, for example into a heated home.
I just watched a demonstration by Dan Ackerman last Thursday night on turning boxes. Dan has a neat trick of mounting his box blank onto a glue chuck that is fitted with a threaded insert that screws onto a chuck mounted on his lathe spindle that has a machinist thread to accept the threaded insert. This way he can rough turn and set it aside and be sure that the piece will mount exactly onto the spindle again. If the wood does not run true when remounted, he knows the wood has changed. I got the feeling that he repeats this until the wood does not move when remounted. Dan sells his little boxes for high prices and they are exquisite.
More Woodturning Website
Re: First box
Re: First box
>Fred
Thanks Fred. You explain how some turner uses a threaded glue block, glued to his turning. That is exactly how I do mine. I always keep about 6 or 8 of these threaded blocks ready to go, when the turning is finished I part the glue block off and use it again on another.If you take it off the lathe and put it on again later it will wobble, guaranteed. So what, you just need to turn a little more off and your back running concentric. I turn everything wet and, Fred there is an answer for everything. If I had to wait for wood to dry for months on end I know I would quit turning, and I am not about to quit. The thing a wet turner has to do a lot of times and do it correctly. You need to seal the inside and outside of a turning so they both dry equally. The wood is still wet but it dry's at the same speed inside and out.Don't do it right and it splits. Cost me under $30 at Beal to turn my first threaded glue block to mount on the headstock ,then mount a scrap piece to this and no more face plate. Mitch
