Making a groove *LINK*
Tony - Memphis
>I just bought a peppermill mechanism from Lee Valley that requires a notch/groove be milled into a hole. I've got some ideas on how I could achieve that, but I thought I'd ask if you had any better/proven ideas! Thanks for the help. Looks like a nice mechanism, btw.
Tony
It is the shaftless mechanism....
http://www.leevalley.com/wood/page.aspx?c=2&p=57737&cat=1,250,43243
Re: Making a groove *LINK*
Re: Making a groove
jwoodwright
>Tony, after looking at the instructions, I believe I have a solution.
Grind a 1/4" Allen wrench into a right angle scraper. Keep "cutting" end square to make the "lip". The lip is needed to hook the mechanism.
So, flatten the top of the allen wrench and give it a rake angle of about 10 degrees. Make a handle and "cut" your groove... John K.
Re: Making a groove
>I made some mills with those mechanisms (a couple using the shaft mechanism of cocobolo and dogwood, below). I used a dremel with a small toothed cutting wheel (a bit like a miniature circular saw blade except relatively thicker) to cut the groove. I've read instructions from others who simply cut the hooks off the fingers and epoxied the mechanism into place but I didn't like that idea as much. Note that you only need to cut the groove deep where aligned with the hooks on the mechanism.
BTW, this is a smooth-grinding mechanism. Just don't loose the spring in the shavings when taking it apart! On the version without the shaft, I found a fat o-ring that made the stopper fit snugly but still easy to remove.
Thanks!
Tony - Memphis
